Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 07-17-2007, 02:27 AM
sexyrex sexyrex is offline
4L60E 96 s10 into 96 tahoe
does any one know if the 60e will fit into the 96 tahoe coming from 95 s10(w)? direct swap or will i have to modify something?
Old 07-17-2007, 02:48 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 4L60E 96 s10 into 96 tahoe
Will it fit? Perhaps. Will it last? Not a chance.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-17-2007, 02:51 AM
what do u mean? arent all the parts the same?
Old 07-17-2007, 10:34 AM
Blue Bowtie's Avatar
Registered Offender
What silicon was hinting at is that the V-6 version possibly (likely) has only 5 clutch discs in the forward (3-4) clutch stack. The V-8 version will likely have 6, and really should have 7 clutch discs and steels.
So, your question can be answered with a qualified "yes" - The parts are the same, but one of the transmissions probably has more of them. There will likely be other subtle differences, and that's IF both transmissions are the same variety, i.e., if they were both designed for 4WD or 2WD.
Old 07-17-2007, 11:28 PM
alright thx alot! i'm probably better off rebuilding than...
Old 07-21-2007, 10:29 AM
wafrederick wafrederick is offline
Banned
The interchange is 1996 only,Looked it up in an interchange book once called a hollander.1995 is by itself too,looked this up in the hollander interchange book too.
Old 07-21-2007, 01:38 PM
UPDATE: transmission is fixed! it was pretty simple. i had no prndl lights, no tach, no speedo, and seemed like it was stuck in third...intermittently transmission would work with an engine restart. googled ignition switch. called the jobber and they actually had one in stock. all working good now!
