Go Back   Automotive Forums Car Chat > Dodge > Caravan | Voyager
Old 06-16-2007, 07:56 PM
gfrancis gfrancis is offline
Cool electical problem???
Hi, my van wont start, while driving the other day the air bag light came on,(and was on for a sec, and went back off) and the interior lights started to flash on and off and the power locks started clicking...now there is a clicking noise not coming from the engine its under the dash, by the fuse box....Now it want start, wont even crank over and the electic locks wont work........email me @...glefromks2002@yahoo....
Old 06-16-2007, 07:57 PM
meddleswithmetal meddleswithmetal is offline
Re: electical problem???
sounds like the body control module to me....
Old 06-16-2007, 08:08 PM
Okay, Is this hard to fix? where is is located at? How much they cost? Or should i take it to be fixed?
Old 06-16-2007, 09:05 PM
Stretch58 Stretch58 is offline
Sounds electrical alright. Start with the battery, make sure you have a good one.
Retired USAF/ Nuclear Plant Controls Dude
Had Recently
1996 Caravan 3.0 Great Car
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 06-17-2007, 02:48 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Model Year?
The BCM should be on the back side of the junction block under the left side of the dash. It's in the mix but, as stated, look at the battery first. Make sure it is fully charged and the posts are shinny clean and tight. Car computers are sensitive to weak batteries. Make sure the battery ground connection to the frame is clean and tight.
EDIT - should be left side of the dash.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 06-17-2007, 11:43 PM
Originally Posted by RIP
Model Year?
The BCM should be on the back side of the junction block under the right side of the dash. It's in the mix but, as stated, look at the battery first. Make sure it is fully charged and the posts are shinny clean and tight. Car computers are sensitive to weak batteries. Make sure the battery ground connection to the frame is clean and tight.
2000 Dodge Caravan 3.0 liters.....
Old 06-24-2007, 11:37 AM
Thanks, it was a dead battery, but now after getting a new battery, my cruise control will not work or the horn, is it possible that i may need to get it re programed after i had that dead battery????
Old 06-24-2007, 11:44 AM
Glad you got the first problem fixed. A new clockspring wiring cable in the steering column/steering wheel should take care of the the other 2 problems. It allows circuits inside the steering wheel, which of course turns. I would have the dealer do it. They may do it for free, there is a recall on it.
Had Recently
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 06-24-2007, 10:08 PM
vipergg vipergg is offline
Might not fix anything but go under the hood in fuse center and find the IOD fuse and pull for a couple minutes and see if anything happens . If the horn and cruise worked before the battery change ok its probably not a clockspring .
Old 06-26-2007, 06:40 PM
Ok, What is the IOD fuse???...which one is it?
Old 07-01-2007, 11:50 AM
It was the clockspring had a recall on it,,Thanks for all your help....
Old 07-01-2007, 12:06 PM
Glenn0921 Glenn0921 is offline
I have a 98 dodge caravan with an electrical problem or something with the Instrument guages going dead then returning to normal, I know it's not a fuse. Can someone tell me could it be a ground wire or what? On very Hot days especially it seems to go out often......Please Help.
Old 07-01-2007, 04:03 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
gfrancis - thanks for posting the fixes
Glenn0921 - no need to post your problem twice
