Go Back   Automotive Forums .com Car Chat > Toyota > Tercel
Old 06-11-2006, 01:24 PM   #1
bobthebiker
Need some minor help. 86 tercel idling rough
I could use a little help on this one. I just bought this car, and the motor idles a bit rough, like it will idle fine, then just drop like it wants to stall, then back to normal idle again. at speed its just fine, but when sitting at a stoplight, it'll do the weird idle mentioned above. I dont know it could just be old fuel, it could be plugs, I just dont know.
Does anyone have some advice on this? I'd like to have it running nice, because I like this little car.
Yoda? you seek yoda? I drive him every day.
bobthebiker is offline   Reply With Quote
Old 06-12-2006, 12:03 AM   #2
KimMG
AF - Advisor
Re: Need some minor help. 86 tercel idling rough
Start by servicing the car. Tune-up, fluid changes, inspect everything especially the vacuum hoses, use a fuel system additive and top off with premium gas, put couple of hundred miles on the car and see if it improves.
KimMG is offline   Reply With Quote
Old 06-13-2007, 12:34 PM   #3
IMPORTHUNTER
Mine does that after plugs, wires, new belts, cap, rotor, fixed the exhaust leak, re done the vac lines, and cleaned the IAC valve and the idle is still real rough, espically when its in drive.
IMPORTHUNTER is offline   Reply With Quote
