Old 10-28-2002, 01:33 AM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
B18 Ls
I have decided to go with ls motor cause i want to get a turbo for it. i can get it for 1000cdn.
what shift linkage do i need?
what ecu?
what rod and pistons?
i know that i will need the b series mounts.
anything else? any other suggestions? please let me know thanks.
My Name is Roberto AKA. Berto
Old 10-29-2002, 04:07 PM
Duatone Duatone is offline
put on a gsr crank, this will allow your powerband to increase constantly across your rpm's, otherwise you will have a rise in hp, then it will drop when you hit between 5-7000 rpm, i beleive. im probably not correct on the rpm, but this is what you should do.
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
