Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-11-2007, 10:21 PM
pughmecdoc pughmecdoc is offline
p0758
My 2001 Rodeo 3.6v auto 2wd. has symptoms of transmission going out. Never had a transmission problem before. But Two weeks ago while leaving the drive-way I suddenly had no power to take off. It would rev to 2K RPMs and start to move but very slowly. Eventually at about 40~45 it has all kinds of get up and go. Two days previous on the way home from work I stopped for gas, shut-off the engine, and would not restart, found the battery dead. So I may have the ATL. problem that everybody here talks about. But The next day here in Louisanna had a Spring storm.. And I drove 7 miles in a flooded street 1/2 foot to 14 inches deep. The next day the symptoms occured. My code reader was taken from my tool box at work.. (I work on aircraft). So I had to wait to get the codes. In the mean time I changed the Trans filter and fluid. Nothing out of sorts found. After reading about winter mode I press the button and it took off 100's of times better. Then today about an hour ago I got the code P758.. Shift Solenoid B Circuit Electrical. I have never had any previous problems other than the P0401. I can find it on the wiring diagram, I am lost other-wise
Does anyone know anything about this. Where the connectors that I need to look at are located?
Thanks
Old 06-12-2007, 11:05 AM
Ramblin Fever Ramblin Fever is offline
Re: p0758
What's your volt output under load for the Alternator?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 06-12-2007, 03:22 PM
Re: p0758
With headlight on and A/C fully on I read 14.3 at the battery terminal
Old 06-13-2007, 02:12 AM
Re: p0758
My friend suggested that I go through the gears.. When I am in L2 it shows L2, but when I shift to L1 it still says L2. Unfortunately I got well into tearing into the center console to do some wire tracing. Since I am off tomorrow. I am going to remove the Switch assy and clean it as others have then follow alignment following hanes. Then go back to the Shift Solenoid B circuit wires. The wiring manual does not show actuation of the switch and how that could effect this solenoid, but it looks like it can. mean while any suggestions are welcome.. Thanks Ramblin Fever for your quick responce.
Old 06-13-2007, 07:17 AM
Re: p0758
You need to check ALTERNATOR output while under load as well; if your alt is lower then 14v's, it's on it's way out.
1997 3.2L V6 Rodeo
Old 06-13-2007, 05:54 PM
Re: p0758
Well when I open up the switch to clean it this morning... Corrosion...I used some of my neat Aircraft cleaner/corrosion remover. And it went back together.. and is now operating correctly.. I had no DC 4 to put in it I will do that in a couple of days.. I will recheck the Alternator directly...
Old 06-13-2007, 06:14 PM
Re: p0758
Well I just tried it and with everything on 13.63 volts. But just in case of another problem, I am going check the shift solenoid wires.
Old 06-13-2007, 10:51 PM
Re: p0758
Don't know much about the shift solenoid wires.
When you go for an alt, make sure you get ONLY a Napa, Bosch, or OEM Isuzu - do not waste time/money on just any reman alternator, these truck's eat em for breakfast.
1997 3.2L V6 Rodeo
Old 06-14-2007, 12:31 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: p0758
If it shows the wrong gear when you move the shift lever its usually a problem with the range sensor. Also causes odd things to happen.
More info.. http://isuzufaq.ibctech.ca/#faq59
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 06-14-2007, 01:39 AM
Re: p0758
Thanks gizmo42.. Yes after I cleaned it half of my conserns went away..I am getting the aLt rebuilt tomorrow.. with life time warrenty $85 plus tax
Old 06-14-2007, 01:44 AM
Re: p0758
Oh The Check engine light went out after cleaning the switch.. Although the L & 2 symptoms remain. I am running 2k rpm @ 60 mph.
Old 06-14-2007, 07:25 AM
Re: p0758
If it's anything other then what I listed above, you're gonna need it for sure. With your basic reman alt, you'll be replacing it every 2-3 weeks or 1-3 mnths depending.
Typical cost for alt's on this truck are over $175
Keep us posted for sure
1997 3.2L V6 Rodeo
Old 06-14-2007, 04:24 PM
Re: p0758
No it is still the origional atl.... It is was re bulit by a shop that just does alt/gen work.... And I already got it back and installed it. Was an extra $30 they had to replace the press in bushings... Anyway it is shifting in the low gears the same way.. now testing with full load it is 14.47v.. Anyone know where the B solenoid located on the transmission
Old 06-16-2007, 03:59 PM
aweaversr aweaversr is offline
Re: p0758
i am also looking for the transmission and no one seems to know the answer. have you found out anything yet?
Old 06-17-2007, 02:11 PM
Re: p0758
I have not found it.. Off to get a detailed Chiltons manual
