Re: Antenna
It was originally on the passenger quarter panel, yes. I'm assuming he shaved it which means one of two things. He did it right and welded up the hole, in which case you should find somewhere else. Or, he did it wrong and slapped bondo over the hole in which case you could probably just punch the bondo out and the reattach the wire to a new antenna. If you end up running a new one all together, just pick the easiest place to mount it.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
