Go Back   Automotive Forums .com Car Chat > MG > MGB
Old 06-10-2007, 10:50 AM   #1
raburns
Alternator Light Intermittent
1978 B and the last couple of times I drive it, the ignition warning light in the middle of the dash comes on.
It will go out and come back on during my drive. I've checked the belt and the connections. They are good.
Is my alternator going out? Is this something that needs to be fixed right away?
raburns is offline   Reply With Quote
Old 06-10-2007, 12:31 PM   #2
KimMG
AF - Advisor
Re: Alternator Light Intermittent
Yes, there is a problem with the charging system, it could be a failing alternator or a poor connection. Some auto parts stores will check the charging system for free.
This subject is being covered in detail at http://www.mgexperience.com
There seems to be a few Bs showing the same symptoms.
KimMG is offline   Reply With Quote
Old 06-11-2007, 06:00 AM   #3
Flash75
AF - Advisor
Check the alternator plug terminals. If they are loose or appear burned or pitted replace the plug terminals. It happend to me, replaced the terminals and solved the problem. Of course it could be something else, it's good simple first check.
Clifton
Flash75 is offline   Reply With Quote
