Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-16-2007, 12:03 AM
timjsowards timjsowards is offline
93 cutlass starts then dies and wont start again for hours
I have a 93 cutlass that i just had in the shop and was told that the cat was bad and clogged so i replaced it and still the same issue, I was then told it was the map sensor, i replaced it, still the same problem, this car will one day drive fine and the next not start and if it does then it may just die and not start again for hours, ive checked the fuel pump, fuel pressure, changed fuel filter, i did all this casue i thought it was a fuel issue but theres fuel to all injectors and spark too all plugs , cranks fine but wont start, its kinda like the two wont work together. Help me , Im very good with cars and this has me stumpt im sure its a sensor but those things arent cheap and i dont want to just start replacing them ,, thanks to all . Tim
Old 06-16-2007, 12:37 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 93 cutlass starts then dies and wont start again for hours
You didnt say what motor but....
I'd check the crankshaft position sensor.
Also check the coils and ignition module are working properly.
1999 Grand Am SS 3.4 OHV
Old 06-16-2007, 01:28 AM
Thanks for the reply, its a 3.1 t v-6 , from what ive read from alot of other post i guess ill try that , if that doesnt do it anyother ideas ? Thanks
Old 02-05-2015, 05:24 PM
jinxyzboi jinxyzboi is offline
There is a wire that controls the ECM power that goes to the "jump post" next to the battery. It's about a 10 gauge wire. There is a fusible link and a connector that links the wire with a "O ring" connector to that "jump post" (there's a red cap on this post) check this for loose connection or corrosion, and check fusible link to make sure its good with a circuit tester. The expand or contract with engine temperature can make a difference on this.
