Old 05-18-2007, 03:18 PM   #1
e7engineer
No Vacuum
Have an 88 w/ 3.1. Problem Runs rough at idle and at higher speeds ( if you can speed up ) Checked Engine vacuum - runs at 5" or less, can not hear any hissing. If it runs for a about 30 seconds the vacuum increases to 22 - 25 ", then drops off. Checked and capped off vacuum lines, blocked off EGR valve, Replaced PCV Valve and hose, replaced intake manifold and plenum gaskets, replaced o-rings on injectors.
I was told to check the timing chain for any slack, There is some slack in the chain. How much is too much slack????
Yes there are multiple questions.
e7engineer is offline   Reply With Quote
