| Completed Projects / Gallery Post all completed works in this sub-forum. |
Revell 1/24 Jordan Mugen Honda EJ10 speed build
For all those that haven't seen my WIP thread, this was built for a 2 week Group Build over on MUG, the aim of the GB was to get modelling, the kit had to be built straight OOB and was to cost no more than GBP10.00 (approx USD20.00).
It didn't help things that I was away for 4 days in the middle of the GB, but I got there in the end, its not my best work, and I only had time to work with the paints at hand, the yellow used is probably slightly too dark and too orange, but its all I had. I may well revisit this kit in the future and give it the works, but it is not revells best by a long way, the fit of some parts is trully atrocious and the breakdown of parts somewhat bewhildering at times. The wheels aren't fitted in most of the shots for a reason they don't fit onto the stub axles that Revell provide, now you would think I'd have tried fitting them before, but as I thought they were going to be a push fit I deliberately didn't, the end result being I have a jordan that the wheels fall off ![]() I'll fix them later, now the pressures off, and before any one comments I'll also do the mirrors in BMF, not that Jarno ever uses his mirrors of course ;-). ![]() ![]() ![]() ![]() ![]() ![]() ![]() It's been fun working to a deadline, and it is good to clear part of the stash. Last edited by Ant Phillips; 04-11-2010 at 06:44 AM. |
Re: Revell 1/24 Jordan Mugen Honda EJ10 speed build
looks nice, but did the kit come with no brake detail? no rotors and no calipers?
In Progress: FXX - test mule in CF 49' Mercury |
Well, if this is a quick build, itīs a very nice one! I wish, some of my long term projects became that good.
Only the tyres are a bit too shiny, you should sand them.
Julian |
, at the rear you again get a one piece moulding but this time both uprights and the drive shafts are moulded as one. As this was for an OOB build, I didn't attempt to add any other detail, but the real problem is the wheels have 2mm hole, but the front stub axle is less than 1 mm diameter , I've fixed it now I cut off the existing stub axle and drilled into the rotor and glued a new shaft of the correct diameter.The rear stubs are better, and I probably could have adapted them to fit, but in the end I opted to make the same fix at the rear too. Quote:
.Now that I've fixed the wheel fitting problem I will probably attempt to sand the wheels to give them a worn finish. |
Nice ping pong table!
Super clean build, very nice looking for a quick OOB build!
Fantastic looking model.I can't believe you built this in just 2 weeks.I love the shot looking into the cockpit,brilliant.
Steve Noble |
The decal sheet design is a credit to Revell, it provides most of the black areas of the car, so painting was a doddle just an overall coat of yellow. I'm definitely tempted to do another Revell F1 car and they do seem to produce some interesting subjects, might get a Sauber or BMW next. |
Nice build. I like the colors, but will take a pass. Thanks for the warning on the kit quality
very very nice work!!! fantastic Jordan!
My Rack |
That's a great looking car for OOB. Nice work you did on this.
Nice speed build!!! How I miss seeing those Jordans.
Well we are going for realism yes? >:-D |
