Go Back   Automotive Forums .com Car Chat > BMW > 7 Series
Old 01-12-2007, 01:12 AM   #1
ZONDERVANUS
ZONDERVANUS's Avatar
Exclamation '94 740 IL Radio Wire Harness Blocks which wire is what ? HELP
I decided to not mess with the CODE on this radio and just get an aftermarket Kenwood..
Situation is that I dont want to spend $30.00 bucks for a Harness Kit and then another $12.00 for an Antenna Adapter so I decided to figure out which wire is which.. the one inside the dash radio plug has multiple colored wires of which i dont know what is what since I dont have a Repair Manual.
Well I managed to take a digital pic of both the block inside the dash and also one of the block behind the radio.. (Hence I butchered the stock radio rear to remove this piece)
My questions is if anyone knows a link to the wire schematic and the colored wires. I'm not cheap to have to buy a repair service manual ; its just simply that I am unemployed and can't afford one at $75.00 on ebay
Here are the pics that I photoshopped to display the numerals on both wire blocks the one behind the stock factory radio and the one attached to the harness inside the Dash.
Inside Dash Radio Wire Harness Block
Rear of Radio Wire Block
BMW 325i E36
ZONDERVANUS is offline   Reply With Quote
Old 01-12-2007, 08:28 AM   #2
Bear
Re: '94 740 IL Radio Wire Harness Blocks which wire is what ? HELP
http://www.e38.org/e32
Yes E38, but look and you will see E32 listed and click on that and then scroll down until; you find the wiring diagrams (pdf) for your year.
Bear is offline   Reply With Quote
Old 01-12-2007, 08:09 PM   #3
ZONDERVANUS
Thumbs up Re: '94 740 IL Radio Wire Harness Blocks which wire is what ? HELP
Thank you Bear....
I will look into this great source of information...
BMW 325i E36
Old 01-13-2007, 11:10 AM   #4
Bear
This is the website you need to pull a schematic of yur cars stereo or any electrical system. the PDF file takes a bit of time to load, but it is there, straight from the BMW ETM.
Old 01-13-2007, 11:50 AM   #5
ZONDERVANUS
I searched incessantly last night on that site address and I still could not find the schematic or diagrams of the actual wires and what their colors are. It just doesnt have it. It simply gives a general outline as to the differences or comparatives between U.S. and European terminology.
Like for instance: Wire Colors
English.............. DIN (German)
Black..................Sw
Blue....................Bl
Brown..................Br
And so on and so on....
I need the complete cluster page of the complete wire harness from headlights to tail lights... There should be a page that shows just interior electronic components such as Radio, Instrument Cluster, even a Hazard Switch .. like what the yellow wire with red dot means... or green wire with white stripe...
I am trying to figure out which ones are my right speaker from my left speaker and so on..
With a test light I was able to find out that:
Position #5 is +12V Switchable (Ignition)
Position #9 is +12V Constant
BMW 325i E36
Old 01-17-2007, 08:03 PM   #6
lincolnmaster80
Hit your nearest future shop or best buy and see if they have a wiring harness for your car. If they do, look on the back and they usually have a list of the wires and their functions. Don't buy it, take a note pad with ya
1990 E32 750iL --> Pictures
Production: 02/1990
Johan and Sean's E32 Page - Repairs and How-to's
E38.org - Information and tech tips for BMW's
Shogun's E32 Tech-Tips
Gale's Repair Page
ETK Online
lincolnmaster80 is offline   Reply With Quote
Old 01-17-2007, 08:10 PM   #7
lincolnmaster80
You can also get out your continuity testor and figure out all the switched, grounds, constants, illumination, and speaker wires...though doing the speakers would require you to test the end in the dash and the positive and negative terminals on the speakers.
When you test the illumination, make sure your dash lights are on and the dimmer is set to a low (dim) setting. You might read less than 8volts on the illumination.
Production: 02/1990
Gale's Repair Page
ETK Online
Old 01-25-2007, 11:22 AM   #8
muleman
Good one. Crutchfield says the harness is free with purchase of a reciever:
http://www.crutchfield.com/S-S9N32cq...=120709195#Tab
muleman is offline   Reply With Quote
Old 01-26-2007, 11:51 AM   #9
lincolnmaster80
Or you could go that route as well. All of the instructions are included with that and they even have vehicle specific installation instructions. Be careful though, if you have the DIN style mounting, you won't need any special mounting kits. You might need antenna adaptors, but I'm not sure on the North American spec E38's. My Jap spec E32 didn't need an adaptor with my aftermarket Alpine deck, so your's might not. But check this before hand.
Post pics of the before and afters! Let us know how it looks!
Production: 02/1990
Gale's Repair Page
ETK Online
Old 05-14-2007, 02:28 PM   #10
kerby
kerby is offline   Reply With Quote
Old 05-15-2007, 08:51 PM   #11
lincolnmaster80
1. left front positive
2. right front positive
3. left rear positive
4. not used*
5. ignition/switched 12v+
6. right rear positive
7. not used*
8. left front negative
9. battery/constant 12v+
10. not used*
11. right front negative
12. left rear negative
13. illumination
14. right rear negative
15. ground 12v-
16. power antenna
17. not used*
* - not used by aftermarket deck.
Production: 02/1990
Gale's Repair Page
ETK Online
