Old 12-02-2004, 09:00 PM
logankelly logankelly is offline
97 lunima rpm
My 97 has no tach it has a 3.1 ,I would like to know the excat rpm at speeds anywhere between 45-70mph, And at what speeds and rpms does the tranny shifts, any input would be helpful
Old 12-03-2004, 12:06 AM
cadgear's Avatar
cadgear cadgear is offline
Re: 97 lunima rpm
Find a used tach-equipped cluster on ebay, ensuring that you find a column/console shift as applicable. Its a straight drop in, you might want to adjust the new cluster's ODO. As far as rough approximation, my 3100 runs about 2200 at 70mph. Approximate. If you want exact, you'll probably need to be electronically inclined and radioshack-friendly or get a scan tool. Or even a cheap scan tool ($120 from auterraweb.com) will display some sensor info.
A rough shift point diagram (from the Unit Repair on service.gm.com):
1-2
TPS %: 12/25/50
Speed: 12/18/29
2-3
TPS %: 12/25/50
Speed: 24/32/51
3-4
TPS %: 12/25/50
Speed: 42/59/101
Downshift:
4-3: TPS 0%, Speed 31mph | TPS 50%, Speed 49mph
3-2: 19mph
2-1: 10mph
TCC Apply:
3rd:
TPS%: 12/25
Speed: 25/38
4th:
TPS%: 12/25
Speed: 39/51
