Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 01-14-2007, 05:41 PM
rob1980_24 rob1980_24 is offline
99 silverado security light comes on
i have a 99 silverado z71 while driving the security light ,batt light,low fuel light come on and th gas gadge reads e, the abs light comes on, i have no gear indicator,no hi-beam indicator light, and the temp. gadge reads that it is still cold even when its blowing heat but the truck still runs fine justwanting to find out what is going on this all happens at the same time also
Old 01-28-2007, 04:43 AM
Dano 00TA Dano 00TA is offline
Re: 99 silverado security light comes on
Check the ground strap between the firewall and engine. I had a weird electrical problem on my 00 and that was the problem, bellhousing bolt was loose. Tightened it up and has been fine ever since.
Old 01-28-2007, 11:14 PM
if i pound on the gas tank the light seems to go out but i comes back on after a while i am thinking it may be the fuel tank sending unit
and has anyone had problems with the trannies on these my fluind looks like pepto bismo i think the coolant is leaking into the tranny
Old 01-29-2007, 08:58 AM
jray06 jray06 is offline
My 01 z71 has the fuel sending unit going out but it doesnt effect anything other than the fuel gauge. Just jumps back and forth from e-f. Sounds like a wiring problem.
Old 04-25-2007, 12:06 AM
tw_zeiser tw_zeiser is offline
I'm having the same problem. I was told that it may be the entire cluster that has to be replaced.
Old 04-25-2007, 02:17 PM
chuck16's Avatar
chuck16 chuck16 is offline
Mine Freaked out like that when the Positive Terminal in the battery was about to fall out. When was the last time you changed your Battery????
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 04-25-2007, 02:54 PM
sc_customs's Avatar
sc_customs sc_customs is offline
Send a message via AIM to sc_customs Send a message via MSN to sc_customs
I've had a similar issue and found that both terminals to the battery were corroded and missing some threads. Replaced the bolts ($2 at autozone) and everything was fine.
I'd also check your grounds too as mentioned. I found a loose ground at the firewall, but that was before I replaced the battery terminals. So it might have been an issue, but we'll never know.
______________________________
2000 Silverado 4.8L V8 (Converted from 4.3L V6)
Edelbrock Ceramic Coated Headers
K&N Fipk Gen. II
Superchips MAX Tuner
Flowmaster 40 Series DF w/3" pipe
Poweraid TB Spacer
Flex-a-lite Electric Fans
3.73 gears w/Eaton posi
Whipple on hold
And those are just the performance mods...
