Go Back   Automotive Forums .com Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-20-2007, 01:02 AM   #1
GSXBMX
Send a message via AIM to GSXBMX Send a message via Yahoo to GSXBMX
boosted 200sx se-r question?
so i am in the process of building up my se-r 200sx to be turbo.here is what i have bought for it:
1) t28 mitsubishi turbo internally wastegated at 8psi and i shimmed it out to about 10psi
2) 30x7x3 bar and plate fmic
3) intercooler piping with all couplers and t bolt clamps
4) hks ssq bov with flange
5) autometer boost gauge
6) sr20det turbo manifold
7) all new gaskets for everything
8) turbo oil inlet/outlet flanges
9) ss braided oil lines with fittings
10) greddy downpipe
11) mandrel bent 3 inch catback exhaust
with these turbo parts and a catback exhaust,whats your opinions on the horsepower gains i could see coming from this kit pushing 10psi?i was hoping 50-75 horsepower
GSXBMX is offline   Reply With Quote
Old 04-20-2007, 11:17 AM   #2
slideways...
slideways...'s Avatar
Re: boosted 200sx se-r question?
seems about right. if i could comment on some of your choices though...
1. mitsu doesnt make t28s. thats a garret turbo. not a bad choice otherwise. you will however have to drill your oil pan. but you knew that right?
2. that intercooler is a bit big for your plans. i suggest a 24x6x2.5
3. make sure the HKS ssqv has an attachment to recirculate. venting a BOV isnt good in a MAF metered car.
once you get all that, i suggest a better braking option.
calipers from a 1991-1993 nissan nx2000 w/ABS (they are a bit bigger and bolt right up)
powerslot rotors from that car (noticeably bigger than the stock rotors on your car)
SS brake lines for a 200sx (the calipers are the same where the line mounts up)
whatever pads you think will suit your needs (the pads should also be for a nx2000 w/ abs application)
all this bolts up without any modification, only you need 15" rims or bigger.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
slideways... is offline   Reply With Quote
