Go Back   Automotive Forums Car Chat > Pontiac > Grand AM
Old 04-16-2007, 12:20 PM
segrandam segrandam is offline
abs and trac off light
someone told me that the wheel sensors might be out
i checked to see if there was power goin to them....
should there be power to the sensors cause i have nothing..
thanks for help
Old 04-16-2007, 02:28 PM
justin0717 justin0717 is offline
Re: abs and trac off light
There wont be any power going to the wheel spd sensors. A wheel speed sensor generates its own AC voltage. If you wanted to test them, there are two wires on the connector, use a DVOM set on AC voltage, and touch both wires, then spin the wheel and see if you get a voltage reading. The reading should go higher the faster you spin the wheel. However, the abs and trac off lamp may be on b/c of a wiring issue from the sensor to the Electronic Brake Control Module (EBCM). Best bet, get the code read from a dealer or someone with a Tech 2, and that will tell you which wheel speed sensor circuit is the issue.
Sorry so long, but hope it helps.
1996 GA SE 2.4L- sold
1999 GA SE 3.4L - newest
Old 04-16-2007, 02:50 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
the easiest way to to check the Ohms, should read around 1000ohm on the sensor.
But it is best to get it scanned with an ABS capable scan tool. Hate to replace one and it wasnt the one
1999 Grand Am SS 3.4 OHV
Old 04-18-2007, 02:28 PM
i heard that i checked and there like 100-120 bucks a piece
i dont feel like droppin that kind of money into the wrong one..
thanks for the help.
