Go Back   Automotive Forums Car Chat > Car Audio
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 03-25-2007, 10:06 AM
Tonglebeak Tonglebeak is offline
flapping noise in subs
Just wondering, if the sub is making a flapping noise while it's hitting hard...is that normal, or is that a sign that the sub is being pushed too far? Or is there something loose in the setup or something?
If it's being pushed too far, how could a 350w rms amp overpower a 400w rms with no noticeable clipping?
Thanks.
1988 Oldsmobile Cutlass Ciera 2.8L V6
Old 03-25-2007, 10:34 AM
jeffman2121 jeffman2121 is offline
Re: flapping noise in subs
while the resistance on the the sub might not be set right with the amp, say you have a 2 ohm sub and you have your amp wired at one ohm, that would be bad, that or if its more of a popping sound that does means its being pushed to hard, so you could fine tune the adjustments on your deck or you could fine tune and or unbridge your amp if it is bridged or put it in a sealed box
Old 03-25-2007, 10:35 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I'll give it a good guess .............. the reason is because you are using a ported box with no subsonic filter. Below the port tuning freq, the sub is virtually unloaded (just like holding the raw driver up in the air with no box) and so it doesn't take much power to bottom the sub out.
Old 03-25-2007, 10:44 AM
I'm sorry for not mentioning this. It's a sealed box. I have the subsonic filter set to 20hz, and the lowpass set to 250hz, so it plays within that range.
You're saying though that if I raise the subsonic filter up, to say 25 or 30hz, it'll stop doing that?
Old 03-25-2007, 11:52 AM
BlasZ24 BlasZ24 is offline
You have the low pass set too high. It could be part of your problem. Lower the low pass filter to below ~60Hz and see if it clears up your problem.
PaulD says: "didn't you know..... electronic devices are made by putting a certain amount of magic smoke in them, when you let out all the smoke it doesn't work anymore."
Old 03-26-2007, 01:52 PM
bjboertje's Avatar
bjboertje bjboertje is offline
having the lowpass too high would not cause the sub to bottom out. just cause localization issues. you should set the low pass around 80hz.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 03-26-2007, 03:18 PM
PlayStation3 PlayStation3 is offline
ok this is now getting weird today when i went out my type r is bottoming out i spent the last 2 hours trying to get it to stop and no luck. btw i have a active xover it's my hu
nm last night i remebered that i helped a freind install his system and i was showing him how to set his gains with a dmm and we used mine as an example and i forgot to set it back.
Old 03-26-2007, 07:01 PM
Audio Guy
it's quite possible tongle is just overdriving his subs
Old 03-26-2007, 07:07 PM
yea causing sqaure waves to get pushed out instead if sine waves
Old 03-26-2007, 07:40 PM
I increased the subsonic filter to 40hz, and decreased the low pass to 90hz. No more flapping.
Old 03-26-2007, 09:12 PM
bjboertje's Avatar
try 30hz for the subsonic, 40 is pretty high.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
