Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 02-14-2007, 08:28 PM   #1
xeroinfinity
out saving the world
xeroinfinity's Avatar
Thumbs up Bleeding your Powersteering
How To Bleed your powersteering system
* You will need to jack the front wheels off the ground,
and properly support them on jack stands.
- First fill the resivoir, and allow it to set for 2-3 minutes.
- Start the car and let it run for 2-3 seconds only.
- Check and refill if necessary as the above procedure until the level is constant.
- Raise the front wheels of the vehicle off the ground.
- Start the engine and increase engine speed to about 1500rpms,
now turn the steering wheel slowly from right stop to left stop.
- With engine running lower the vehicle and turn the steering wheel right-to-left as before without holding at the stops.
- Recheck the fluid level, if its foamy allow it to set for several minutes with the engine off, then repeat the above procedures.
- If its still foamy after several attempts
thier could be something wrong with the PS system(leaks).
- If you replaced the PS hoses, it may take up to 2hrs to fully releave the system of the foamy fluid.
Low fluid level and dirty/contaminated fluid is the cause of pump and rack and pinion failures.
IMO switching to sythetic PS fluid will help your system function better and last longer.
Hope that helps!
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline
Closed Thread
