Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 02-17-2007, 09:45 AM   #1
dugg365
new parts no start
'93 jeep cherokee start and run... after new: plugs, wires, cap, rotor, and battery the engine will not do anything. all fuses are good all electronics in the cockpit work as do exterior electrical. when the ignition switch is engaged the temp. gauge sweeps all the way to the right. did i do someting wrong?
dugg365 is offline   Reply With Quote
Old 02-17-2007, 10:10 AM   #2
bthust
Re: new parts no start
check starter relay
bthust is offline   Reply With Quote
Old 02-19-2007, 09:01 AM   #3
brainyass
brainyass's Avatar
check ignition coil
brainyass is offline   Reply With Quote
Old 02-19-2007, 09:18 AM   #4
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
If it ran fine before you did your work, go back and check all the connections that you worked on, and all the connections nearby.
It could be as simple as the coil wire being unattached (an error I admit to doing several times)
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
Old 02-23-2007, 03:33 AM   #5
hundahunta
bad battery connetion or starter
hundahunta is offline   Reply With Quote
