Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 12-06-2006, 06:40 PM
Tatortot02 Tatortot02 is offline
'93 Civic EX interior LED lights
Alright i was wonderin if there is any quick easy way to put in like a black light in my car. I really dont car if i have to turn it on or w/e. I was just wondering if there was any way to do it without a lot of hastle. Are there such things as colored lights for the cars dome light? I dont wanna have to get into installing a ton of stuff so just wondering if there were such things and if anyone knew where to get em. Thanks
Old 12-08-2006, 01:48 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: '93 Civic EX interior LED lights
Street Glow makes some Black Light Neons. You could get some and install them in the foot wells under the dash and and install some under the seats. Wire them up to a toggle switch. Pretty easy to wire them up. Black wire to ground, postive to postive 12v source. Toggle switch, rocker switch, whatever, to turn it on and off.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 01-10-2007, 01:54 PM
Galuple Galuple is offline
Sorry to bump up this topic after a month but, what would be a good 12V source to tap into in the front footwells?
Old 01-10-2007, 08:16 PM
Copytech99 Copytech99 is offline
The +12 Volt outlet / lighter is a good source for switched (by the key) voltage. A good low current constant source is behind the head unit ( yellow wire if aftermarket)
You should add a fuse to your source line just to be safe.
Old 01-31-2007, 10:50 PM
ThiRteeN's Avatar
ThiRteeN ThiRteeN is offline
Send a message via AIM to ThiRteeN
i wired mine to the cig. lighter wire, just add a higher amp fuse. I put toggle switches on the center consol, behind the e brake. I found this easiest becaues you can run the wire for the neon/LEDs under the seats right out from under the consol, and the ones under the kick panels, jus run the wires out the front of the consol, under the dash. If you need more info. just hit me up.
Definition of Ultimate Rejection:
-When your hand falls asleep while jerking off
-98 Civic DX....R.I.P.
-96 HX...........work in progress
