Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-09-2007, 03:49 PM   #1
tfoti
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
How to bench bleed brake master cylinder?
I am putting on a new master cylinder but need to know how to bench bleed it first. Tuners has been down and I can't find much else on how to do it.
Thanks!
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
tfoti is offline   Reply With Quote
Old 02-09-2007, 06:09 PM   #2
gthompson97
gthompson97's Avatar
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: How to bench bleed brake master cylinder?
Google is your friend, it shouldn't be any different than any other car.
95 Talon TSI AWD
97 Eclipse GST
gthompson97 is offline   Reply With Quote
Old 02-09-2007, 06:44 PM   #3
Blackcrow64
Blackcrow64's Avatar
All you do is fill the resevoir and crack open all the caliper bleeders and let it gravity bleed. This is how I was told to do it at least. We would squeeze the one soft line from the resevoir to the master cylinder to suck the fluid into the master cylinder to speed up the process a bit. Just don't let your resevoir go empty or you'll be workin a lot of fluid out of the lines again...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Blackcrow64 is offline   Reply With Quote
Old 02-10-2007, 03:42 AM   #4
gthompson97
He's doing it off of the car, there's no resirvoir or anything like that.
95 Talon TSI AWD
97 Eclipse GST
Old 02-10-2007, 11:44 AM   #5
tfoti
Testiklees
I actually did it after i put it on the car. The reman came with 2 nylon hoses and 2 plastic fittings that go where the brake lines connect. I just hooked the MC to the reservoir and filled it up, connected the tubes and fittings and submerged them in brake fluid. Had a second person in the car pumping the brakes until all the bubbles came out. Just like you would at the caliper.
Thanks for the responses! Hopefully when I get the rest of the system bled I will actually have some pedal feel...
Tim
1990 Talon AWD
PTE SCM5031
