Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 08-20-2002, 12:50 AM
MattyO217 MattyO217 is offline
How is daily driving with a dropped car?
How is daily driving in your dropped ride? Ride quality, ground clearance, etc. Any response I'll appreciate. Thanks.
I live in Minnesota where we can get quite a bit if snow. Is anyone in a similar enviroment and have their car lowered? Have you had problems with damaging your front bumber, etc.? I have a 99 civic si. I recently bought some neuspeed sport springs along with some bilstein struts (haven't got my camber kit yet). The drop is suppose to be 1.75" (front) and 1.5" (rear). I can also raise the spring perches a maximum of 6mm (~.25"). Also what about steep driveways, speed bumps, roadkill, stuff in the road, cows, etc.?
~M
Old 08-20-2002, 07:54 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
It really depends on the spring rates, your shocks, and the tire sidewall height. Some people say slammed is comfortable and others who are dropped 1" say it's rough. It's all relative.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 08-20-2002, 08:21 AM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
Very true, but I know one thing, you want to do it right to preserve ride quality. I've got 4 blown stock shocks and the ride sucks on coilovers.
Old 08-20-2002, 11:35 AM
delsolsi delsolsi is offline
Re: How is daily driving with a dropped car?
It all depends on your set up and what you like. I've never used bilstein struts or neuspeed springs, but these aren't racing units so they should be ok.
I live in Washington state. It snows alittle bit here, but nothing like in minnesota. I've noticed its a little bit harder to drive in bad conditions with a stiffer suspension, but the tires make a bigger difference.
~M
Drive over them slow or avoid them.
Old 09-04-2002, 10:36 PM
silveraccord96 silveraccord96 is offline
I have a 96 Accord thats dropped 4 inches in the front and 3.5 in back and I live in New York. This will be the first winter i've had the car lowered, i might raise it back up. I Scrape on a lot of stuff now cause the roads in NY are horrible cause of the winters. Train tracks i have to stop and go real slow in 1st. any kinda bump in the road i have to go slow. I can go over some smaller speed bumps if i go real slow, But i have felt the whole frame of my car scrape on some speedbumps. Also the flange on the exhuast pipes right by the rear axle scrapes on a lot of stuff. The front bumper is all scraped underneath from driveways. I even broke the lexan casing on my front underbody neon tube one day. The ride is bumpy with the stock shocks and struts but im used to it now and its not that bad. Just watch out for any change in the road and take it slow until u know where all the bumps and pot holes are. The car looks hot slammed and i recomend doing it to your car, but be sure to keep ur stock tires for the winter and buy adjustable coilovers so u can raise it up for the winter.
Old 09-05-2002, 12:52 PM
Civic Mod
Being too low is not always the best. People get this thought if low is good lower is better, which is not always true.
It would be like saying if two Tylenol for a headache is good, than 10 is better.
When you are too low you run out of shock travel and then your shocks don't to what they are to do - dampen your springs to keep you from bouncing.
Autocross Help Page
Buy my Civic parts!
Old 09-06-2002, 05:35 AM
Rein Rein is offline
Send a message via AIM to Rein
Could be worse...you could have 4 blown shocks on stock springs...haha, I saw a car with that on the freeway and if I was in that shit I would get seasick in 2 minutes.
1998 Audi A4 1.8T
*APR turbo back exhaust
*APR 1.0 bar chip upgrade (+40 hp, 88ft-lbs)
*Axis Seven 18s
Future mods:
*H&R full coilover suspension
*APR Stage III+ Turbo Kit (310 hp, 345 ft lbs)
*Stop Tech Slotted Big Brake Kit
Click here to check out my car on Cardomain.com
Secondary car: Black 1992 Civic Si
"Every man dies. Not every man really lives"
Old 10-05-2002, 09:10 PM
Can anyone tell me more about their experience with ground clearance? How is it with steep inclines (like driveways), speed bumps, potholes, stuff in the road, etc? Also, I live in Minnesota where we can get a lot of snow. I do have good snow tires (Bridgestone Blizzacks -- spelling?), but am concerned about becoming a snowplow with the 1.75/1.5" drop on my 99 Si. Can it do damage like to the front bumper or to anything else?
Thanks for any more input,
~M
:bandit:
Old 10-07-2002, 03:12 PM
Goosse's Avatar
Goosse Goosse is offline
Send a message via AIM to Goosse
My car is dropped somewhere around 2.5" front and rear and I have no problems what so ever when I'm on the road (and their are a lot of speed bumps over here). I ony scrape when I try to get into my garage (which is under our house). My car is dropped with Spax lowering springs on Koni Yellows and the handling is very good. Turns that I used to take at 50kmh, I can now take at 75kmh
If I put my front lip on my car, I can barely put my shoe under the front
Old 10-07-2002, 09:10 PM
Civic Mod
You learn to navigate around speed bumps and inclines. For inclines you want to go at it at an angle so one wheel gets on the hill then the other.
For speed bumps you do the same thing depending on how high they are. I usually just find another way around them
Autocross Help Page
Buy my Civic parts!
Old 10-08-2002, 04:20 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
That's about all there is to it. But becarful, lately I've been having a problem of even angling down driveway ramps, the bottom of my car (resonator to my exhaust to be specific) has scrapped the top part of the ramp, as it gets closer to the car as you go down the ramp, till your back wheels go over it. It just happened to me yesterday when my car almost highsided (where the car is sitting with the drive wheels off the ground, stuck) going down a driveway ramp that meets the street, as soon as I heard it start to scrape, and knew I was at least a foot from the actual street surface still, I reversed and had to find another exit. It sucks sometimes, but it can be worked around. Just don't drop your car too much, and you should be fine. My car sits lower than most I know that are slammed on "17's, because since I have "15 rims, I can actually lower more to the wheels than if I had "17's. And I STILL have about 1/8 inch of wheel gap, and I still sit lower than a buddy of mine who has her car slammed to the fenders on "17's.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 10-13-2002, 10:37 PM
CustomWhips's Avatar
CustomWhips CustomWhips is offline
Send a message via AIM to CustomWhips
æ
took awhile to get used to. (parks far from side walks now)
rides not as luxurious but its alot more comfortable. handles a little better.
dinged the crap out of my bumper but its a factory bumper so fuck it.
but its a hell of alot better then 5 inches of space between your wheel and fenders
Would you drive a different car than your own? Lionkind Cars in General 0 04-01-2009 08:04 PM
Advice on low mileage driving with new car - remote starter, oil changes, etc. wickster Engineering/ Technical 4 12-01-2003 01:25 PM
