Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 02-10-2007, 09:44 AM   #1
drpaul87
2001 Cherokee "cricket"
I need help!!!!! (besides the mental type Within the last couple of days, when I start driving, I have a chirping that goes with wheel speed. It has been collllllddddd here (PA). When it warms up a bit, the chirping stops. My big concern would be wheel bearing. I am thinking more likely brakes just getting to the squealie indicator. Any suggestions?
Thanks a bunch.
Paul
2001 Cherokee, 6 cyl. 4wd....86700
1987 Comanche, 4cyl, 5 spd....122000
drpaul87 is offline   Reply With Quote
Old 02-10-2007, 06:59 PM   #2
AlohaBra
AlohaBra's Avatar
Cool Re: 2001 Cherokee "cricket"
With the "ecco" alloy wheels, the center cover that has 'Jeep' on it will sqeak or chirp. You can hear it when driving slowly.
The disc brake pads on an XJ does not have a squeak indicator. The pads could chirp but will stop when you press on the brake pedal a little bit.
Wheel bearings don't chirp usually, they knd of growl.
Which end, front or back?
AlohaBra is offline   Reply With Quote
Old 02-11-2007, 07:24 AM   #3
drpaul87
It sounds to me to be the front left. Did the drive with the door open thing it has just been too cold to crawl around under it, even in the garage. It seems to be mostly annoying, but don't want it to lead to bad later
