Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 02-03-2007, 01:01 AM   #1
ECain
Send a message via AIM to ECain Send a message via Yahoo to ECain
Radiator woes
So my roomate failed to mention that when he used my Blazer, he also topped my rad with water - which then froze over night.
I need dethawing ideas quick.
Thanks in advance
ECain is offline   Reply With Quote
Old 02-03-2007, 01:28 AM   #2
paxfam1
Re: Radiator woes
Thanks in advance
Well, has it done any damage?? I would warm the vechile up really good then drain the coolant out of it, and replace with the coolant of your choice, Red or Green................What ever your supposed to have in it.
paxfam1 is offline   Reply With Quote
Old 02-03-2007, 03:36 AM   #3
ECain
Re: Radiator woes
Well, i pushed it around my complex and into my garage where I now have a small space heater blowing underneath the front of the vehicle. I'm going to give it a good 12 hours MINIMUM then try a drain/refill. Wish my dumb-arse some luck on this one.
Old 02-03-2007, 08:44 PM   #4
DelCoch
DelCoch's Avatar
Re: Radiator woes
Did he just add water to the overflow reservoir or to the radiator itself? If just the reservoir and if the reservoir don't leak when thawed out I doubt it did any damage. I would pick up an antifreeze checker at the parts store, (they are cheap) remove the radiator cap and test the strength of the antifreeze before replacing it. Drain the water out of the overflow tank before driving it.
DelCoch is offline   Reply With Quote
Old 02-03-2007, 10:09 PM   #5
ECain
Re: Radiator woes
Whelp, thawed that sad pup out, drained & refilled the coolant, sat there long thinking hard about if I ought to turn it over or not...finally did and thanked my lucky ass it started up with no issues. I dodge yet another bullet.opcorn:
