oil pressure
My oil pressure gauge has been running very low. Can anyone tell me what the normal operating range is? Thank you. 2000 blazer 4.3 v6
Re: oil pressure
Rule of thumb is a 1/4 gauge or more at idle and 3/4 gauge at 3000 RPM. But better to put a manual test gauge on it and see what the actual pressure is. Post back pressure with a manual test gauge.
Re: oil pressure
if you want to use the dash guage as a reference, oil psi is usually 25-35 at idle and 40-50 under load. this is with the engine up to temp. if you want to know the true reading, use a mechanical guage like MT said.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
Re: oil pressure
Thank you for the information. I don't have an oil pressure tester, but I am planning on getting one soon.
Re: oil pressure
That is the only true test Dash gauge is only a electrical Indicator and sending units can go bad. Another note if you are not using a AC delco oil filter get one and see if it improves oil presure. Let us know how it goes.
