Old 01-16-2007, 07:35 PM
DavidKim91 DavidKim91 is offline
dumb question but need help
ok u guys probibly think its really dumb but i dont exactly get torque..
i know it like foot pounds n stuff.. but thats as far as i got..
could someone plz explain this to me .. better.. lol
thanks alot
oh and im just learning bout cars so if u could fill me in on some other stuff or tell me what i can do to learn more that would be awesome.... i know its alot to ask for but worth a try..thx
Old 01-16-2007, 07:48 PM
GreyGoose006 GreyGoose006 is offline
Re: dumb question but need help
its pretty simple.
torque is a static measurment of force.
in relation to an engine, it is a measurement of how much work an engine can do.
hosepower is (in engine-speak) torque x rpm
basically, think of it like this.
torque is how much work an engine can do.
horsepower is how quickly it can do that work.
Old 01-16-2007, 07:50 PM
but what does foot pounds have to do with all of that??
and thx for the reply
Old 01-16-2007, 08:00 PM
gouldie1903 gouldie1903 is offline
it's the measurement used for rotational force.
67 chevy c 10 needs paint
01 mustang gt needs hp
Old 01-16-2007, 08:01 PM
rotational force.... as in the crankshaft?
lol
Old 01-16-2007, 09:35 PM
well foot pounds is a unit of measurment of torque.
it is like this.
if you are tightening a bolt, and you have a 2 foot long wrench and put 50 pounds of force on to the end of the wrench, you are putting 100 foot pounds of torque on the bolt.
same with a 4 foot long wrench and 25 pounds of force.
or a 1 foot long wrench and 100 pounds of force
when measuring torque on an engine, the dyno is measuring the ammount of torque that the engine can produce as the dyno is resisting the rotation of the wheels/crank
the dyno then converts this information to horsepower.
Old 01-16-2007, 11:54 PM
KiwiBacon KiwiBacon is offline
Torque is a twisting force.
Put a 1lb weight on a lever 1ft long and you get 1 fl-lb of torque at the end of the lever.
Old 01-18-2007, 01:14 AM
UncleBob UncleBob is offline
AF -Advisor
*cough* other way around. Dyno measures the drum acceleration at X mph over X time (aka "work" over "time"...with a intertia drum dyno anyway) which is converted to HP then converted to engine torque
In short, torque is a static measurement. It does not involve movement and time. As soon as time and movement is involved, its HP. HP is a dynamic measurement. (ie real-world)
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 01-18-2007, 10:12 AM
2turboimports's Avatar
2turboimports 2turboimports is offline
Torque is not work done. Work done means something has moved. You can apply torque w/out doing any work. It can be simply put as
Torque = Force x Radius
Better off put, Torque is a cross product between the radius and force.
t = F x r. But that touches on vectors and may not be appropriate for this thread.
Didn't even see that in your post. +1
Old 01-18-2007, 06:57 PM
To continue along those lines:
Work done (Joules) = Torque (Nm)*Rotation (radians)
Power (watts or joules/second) = Torque(Nm) * Rotating speed (radians per second).
Old 01-18-2007, 08:16 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
if this was right it would mean that work is measured in N * m * radians. it's just newton meters, which are equivalent to joules. as well, power is work/time and work is measured in newton meters, time in seconds, this would mean power = Nm/s, not Nm*radians/s.
if you want a vector definition of torque, then it's the cross product of the force and the distance from the point where the torque is applied (and it's r X F, not F X r, i got screwed with that mistake on my exam this year). it's pretty much a measure of a rotational force on a point, with no time or movement involved.
when applying it to cars, it's how much rotational force the engine can apply at a certain rpm. horsepower is how much work the engine can do in a certain ammount of time.
since work (w) equals a force over a distance (F*d) then power is how quickly you can apply that force over that distance. so if you have 100 Watts (N*m/s) you can apply 100 Newtons over 1 meter in 1 second, 50 newtons over 2 meters in 1 second, etc.
hope this clarified things up, i find it more difficult to think of torque relating to cars vs torque relating to wrenches and such (although a wrench system is different from what you think it is, as i learned in mechanics I this year)
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 01-18-2007, 08:59 PM
well thats why the units are different.
wrench torque is measured with different units than car torque.
one is lbft one is ftlbs... i dont remember which is which, but they are completely different.
BUT...
in both cases, torque is measuring a force that is static and not related to time.
Old 01-18-2007, 09:04 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
nope, they're the same.
it's a personal prefrence thing, some people say ft-lbs and some say lb/ft.
still pounds per foot.
Seatbelts Saved My Life
Old 01-18-2007, 09:13 PM
right but seeing as how they are so different, it is sort of agreed that wrench torque is meausred with different units than car torque.
at least thats how it is here in the US
Old 01-18-2007, 09:15 PM
never come accross that.
i've also known ft-lbs and lb/ft as the same thing, exactly the same. we get torque wrenches in lb/ft or ft-lbs and they're the same except for whether the manufacturer puts lb/ft or ft-lbs on the gauge.
