Old 03-05-2005, 12:41 PM   #1
countryroadhouse
Send a message via Yahoo to countryroadhouse
95 rodeo will not start
Having problem here with my 95 rodeo 3.2 engine. Replaced timing belt and crank position sensor. Its getting fuel.. I cleaned the egr valve and when i try to start it, it tries to start but acts as if its out of time.. Before it died on me, it would have a no start problem, and sometimes it would start ....i have spark but it is weak . Could it be the electronic control module, plugs or wires need help here
countryroadhouse is offline   Reply With Quote
Old 03-05-2005, 12:47 PM   #2
countryroadhouse
Re: 95 rodeo will not start
ps... there are no codes present and the check engine light has never came on
Old 03-05-2005, 02:16 PM   #3
Canucklehead
Send a message via MSN to Canucklehead
Are you sure the timing belt marks were lined up correctly when you installed it?
2000 VW New Beetle TDI
2007 Honda CR-V
Canucklehead is offline   Reply With Quote
Old 03-05-2005, 05:15 PM   #4
countryroadhouse
Re: Re: 95 rodeo will not start
yes alll marks on belt aligned with camshafts and crank
Old 01-23-2007, 02:39 PM   #5
Darius03
I have similar problem and the shop wher I brought my 95 Isuzu Rodeo said that the diagnostics came up with the electroni control module failure.
It is a very expensive part - the electronic control module upwards of $700.
Anyone in this forum who can give me an idea as to the failure rate of the electronic control module in the Rodeo or any car for that matter?
Darius03 is offline   Reply With Quote
Old 01-23-2007, 04:54 PM   #6
amigo-2k
Isuzu Guy
never heard of one failing.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
Old 01-23-2007, 05:38 PM   #7
surferfletch
I'd be curious to know the exact codes. I would suspect a coilpack before the ECM.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
surferfletch is offline   Reply With Quote
