Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier
Old 12-25-2006, 02:42 AM
MVGTP86 MVGTP86 is offline
Has anyone w/ a cavi on this forum done an L67 engine swap?
My g/f's cavi is ready to die.....plus i just want to do this swap b/c i know its been done and the results can be outstanding in performance...I have a used L67 block (3.8L Supercharged)(i had a new one put it in this fall its out of my GTP) in my garage and wanted to rebuild it and swap it in my girlfriends cavi..I know i need a better transmission, hers is bad anyways and a stock cavi tranny couldnt take that power anyway..Does anyone have any suggestions or tips if they have done this swap or know of any write-ups on it??
Thanks.
2003 GTP - Brand New L67 crate engine, K&N FWI, Ported TB, 3.4 s/c pulley, Walbro 340 fuel pump, 180* T-stat, 1.9's, PEM'S, ZZP 3" Down Pipe, ZZP 1.0 PCM, gutted cat, u/bend - resonator delete, magnaflow mufflers and tips.
Old 12-25-2006, 08:28 AM
PulledOverAgain PulledOverAgain is offline
Re: Has anyone w/ a cavi on this forum done an L67 engine swap?
Try going to
http://forums.motorswap.org/
One of the forums is "J-body Think Tank". There's guys in there that have done the swap.
And if it's an 00+ 5spd cavy. Yes, the stock tranny WILL hold that much power.
Old 12-25-2006, 11:20 AM
Originally Posted by PulledOverAgain
Try going to
Ok thanks for the link...she has a 97 w/ the 4speed auto so it wouldnt hold up very well....especially if you mod the engine very much...so ill probably need to beef it up a bit with new gears and bands and stuff....
Old 12-26-2006, 01:20 PM
Max input on the 4t40 and the 4t45 (which should be really easy to convert to) is supposed to be 325 ft/lbs. So you'd be under the limit, but barely. I'm sure there's a way to get the 4t65e-hd in there though, i've seen it done before.
Or, one guy runs a Getrag 5spd with a 3.4" pulley and some N2O.
