Old 09-21-2002, 10:52 PM   #1
noreaga0221
Send a message via AIM to noreaga0221 Send a message via Yahoo to noreaga0221
only a 3 speed now help!
ok i was driving fine and went through all the gears a couple times already. i get to this light then make a u turn. first-- fine then second --fine then third varooooomm, seemed like it was still in neutral. hit the clutch and tried to put it back it but it was already in but there was no gear there. tried fourth-- same thing. but 5th and reverse are fine. everything else seems fine, no engine light, no extra noise no loss of performance. i'm thinking a shifter cable snapped since my car does have like 104thousand miles on it.
did this every happen to anybody or what? if so how did you get it fixed and how much was it. and could i do it myself?
also on a side note.. does anybody know why www.dsmtalk.com shut down the registration. i've been trying everyday for over 2 weeks but still says they are disabled.
loooking for my first kill....
noreaga0221 is offline   Reply With Quote
Old 09-22-2002, 10:47 AM   #2
eclipse_99rs
Im not a tranny expert but it sounds like a bad syncro. I had the same problem with trying to sign up to dsmtalk. I think its to keep the site from getting out of control numbers wise. You can also try www.2gnt.com I know its for non turboes but there are quite a few guys on there with turboes and also a turbo 4g63 and 1g section in the forums. hope i helped!
eclipse_99rs is offline   Reply With Quote
Old 09-22-2002, 10:52 AM   #3
noreaga0221
but if it was a bad syncro wouldnt i still be able to get into those gears with double clutching? and how would 2 gears go at exactly the same time?
Caravan only gets to 25mph then slows dieter Caravan | Voyager 4 08-06-2009 06:23 AM
97 buick lesabre fan blower only speed 3 uniform man LeSabre 3 08-05-2006 03:39 PM
Koenigsegg was betetr in top speed, now it is also better at the Nürburgring:-7,30 s Gustav F1 1 06-28-2005 02:36 PM
97 GP Went DEAD at speed - now no start! PonchoLuv Grand Prix 1 04-15-2005 10:59 PM
How do you guys feel about AF's speed now? igor@af COMPLETELY off-topic 15 10-07-2003 07:11 PM
