stock amp
anyone know where the stock amp is in an 03 tiburon
Re: stock amp
drivers side rear quater panel...
you have to take off the interior rear panel... pop off the long strip by the side skirts, careful not to break it... then itll expose where you deed to pull to get the quater panel off... theyre all clips (i dont think theres any screws) and you can jus pop em back on... why whats wrong with the stock amp... ohh and only the 03+s with the infinity/ jbl system have amps...
almost that time ![]() my sig made mommies cry, thats why i had to change it.. |
Re: stock amp
yeah i got the infinity system, reason is because i put in a after market radio and it was good for a couple weeks then i was cruisin down the street and smelled what seemed to be a amp burning out and out went the sound. i hooked the stock radio back up and still no sound so im narrowing it down to the amp. do you know if it has a fuse? if it doesnt im gonna bypass it. i also found that the amp supplys all the speakers.
Re: stock amp
fuses are by your left leg, youll see a square and pop that out....
all teh fuses are there
about the stock infiniti amp bypass
i was wondering how do u bypass the stock infiniti amp. i have an 05 tiburon and i need to do that befor i install my stuff.. i have been looking for bypass harness's but i cant seem to find them.. please explane to me how i can bypass this amp.. thankyou
Chris |
Re: stock amp
is there a control for the power on the amp... I'd like my sub to hit a lil harder. I've already done the lil wire switch trick, and i didn't get much improvement!
Re: stock amp
youll need an aftermarket amp, and a afternmarket sub set up if you want the subs to hit harder
Re: about the stock infiniti amp bypass
if youre not gonna be using it why not take it out?
Unfortunately you can not bypass the new infinity amps. They are ran on a databus system that there is no bypass for. It can only be ran off of the factory deck. You will have to run all your speaker leads separately off of your new deck.
Unfortunately you can not bypass the factory amp because it is ran off of a databus system. The most sophisticated part of the tiburon is the stereo if you can believe that. There is no bypass for the data bus systems. You will have to run all of your leads individually to each speaker off of your new deck. I did it not too hard. you have to drill holes for the leads in the doors though.
Re: stock amp
cant you just run speaker wire from the aftermarket radio to the factory amy outputs to the speakers instead of runnung speaker wire through the doors and all of that extra crap.
Re: stock amp
On the 03's yes can. But the stock speaker wire is light gauge.
