Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 12-04-2006, 08:01 PM   #1
StillGoin5.0
Send a message via AIM to StillGoin5.0
cap and rotor burnt!
i put a brand new MSD billit dist. in my 87 5.0 2 months ago and just the other day the car started running really rich and little rough at around 2000 rpm in any gear. the A/F guage is pegged all the way on rich now. i noticed that the cap points have alot of crust on them and the rotor does too. also the spark plug wires have a little rust in the boots especially the coil wire. could the cap and rotor be burnt out b/c of the bad plug wires and the reason its running rich is because its not getting enough spark?
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
StillGoin5.0 is offline   Reply With Quote
