| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Oversized Valve guides??? HELP
Okay so I decided I am going to go with oversized valves and get a 5 angle valve job done. But, while I was looking at valve guides on slowboyracing.com I found bronze valve guides. The problem is that they offer a standard size and 1mm over. Do I need the oversized guides with oversized valves?
95 GSX 5 speed 2.3L stroker bored .020 over Built head Bullseye/Borg Warner T04B 57 Trim Turbo RNR 3" turboback w/ o2 eliminator 255 lph Extreme Motorsports fuel pump Extreme Motorsports mbc SAFC Greddy Type S BOV FMIC (core 28x10.5x3.5) FIC 650cc fuel injectors RK Sport Fuel Pressure Regulator My Car Domain |
Re: Oversized Valve guides??? HELP
Yes, but may I ask why are you going with oversized valves? Are you going to need them? With OS valves, the valves and pistons run a closer tolerance then with stockers, and that means that you have that much less space to mess up with on timing before something bends. Unless you ABSOLUTLEY need them, I would just stick with SS stock valves.
Yeah, thanks. I have decided to go with stainless steel valves and keep the stock size. BTW the valves I want come with a nitrided option. The option does not cost more but, what is nitrided? Anything special? Heres the link http://www.slowboyracing.com/more.php?id=1129&
It's a hardening treatment for the valves.
its like heat treatment for exhaust manifold bolts. damn exhaust manifold bolts..
