Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 09-01-2004, 11:10 AM   #1
psanchez
Question 2001 chevy tahoe stalling in low speeds???
I have been having stalling problems with my 2001 chevy tahoe LT. It has just got worst, before it would stall maybe once every three weeks, then it was once a week, now it just got worst it does it everyday, just this morning on the way to work it stalled three times. It only does it in low speeds, like this morning i was in traffic and when you let go of the gas pedal the truck shakes and turns off. The electrical stays on like the radio and lights, but when it stalls i do not get a message in the message center, the only thing that shows up is the battery light. after it stalls it starts back up right away, but today it did something weird, after it stalled the second time and i started it, my fuel showed low fuel it was on empty even though it had gas, then it stalled again, and it started back up and the gas gauge went back to normal. it also does it alot when i'm parking. very weird, i am so fraustrated with this truck, you would think a truck this new would do things like that. i have read other forums stating to change the crank shaft sensor????? i have already changed my fuel filter. please help.
psanchez is offline   Reply With Quote
Old 09-01-2004, 12:33 PM   #2
GMMerlin
I know stuff
GMMerlin's Avatar
Re: 2001 chevy tahoe stalling in low speeds???
if this problem only happens when your foot is off the gas pedal, I would recommend you clean the throttle body first.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 09-01-2004, 12:51 PM   #3
psanchez
Re: Re: 2001 chevy tahoe stalling in low speeds???
THANK YOU FOR RESPONDING, HOW DO YOU CLEAN THE THROTTLE BODY?
Old 09-02-2004, 09:17 AM   #4
GMMerlin
I know stuff
GMMerlin's Avatar
With the engine OFF
Remove the duct from the air filter box to the throttle body...spray some choke cleaner into the throttle body and scrub the housing and blade with a soft tooth brush..spray again and wipe clean.
There are some GM TSB's on this concern also
GM WCT
PM Me for details
Old 09-02-2004, 11:02 AM   #5
psanchez
With the engine OFF
this is probably a dumb question but what does GM TSB's mean? bullentins?
Old 09-02-2004, 01:01 PM   #6
GMMerlin
I know stuff
GMMerlin's Avatar
General Motors Technical Service Bulletin
GM WCT
PM Me for details
Old 09-02-2004, 05:17 PM   #7
bartlanz
bartlanz's Avatar
Send a message via ICQ to bartlanz Send a message via AIM to bartlanz
Depending on your milage, I might also think about doing your fule filter. Could be that when the vehicle is at speed is it sucking it through, how ever at idle it may not have enough emph to do it.
Just and idea.
Bart
98 Tahoe LT
K&N Drop in Air Filter
Rancho 5000 Shocks all around
265/75R16 BFGoodrich Allterain T/A KO Tires
WHELEN 9600 Series, 10 Strobe, Light Bar with Smart Messenger
ALPINE CDA-9835 CD/MP3 Player
My Ride
bartlanz is offline   Reply With Quote
Old 09-02-2004, 08:14 PM   #8
GMMerlin
I know stuff
GMMerlin's Avatar
Just and idea.
Good thought, but this system does not "suck" gas, the fuel pump pushes fuel through the rail..a clogged fuel filter will cause a problem during high demand (acceleration)
GM WCT
PM Me for details
Old 09-03-2004, 12:31 PM   #9
psanchez
Just and idea.
thank you so much for you response and idea, but i have changed my fuel filter, because i was also thinking it was that, but it still stalls, but atleast i have a new fuel filter. thanks.
Old 09-28-2004, 11:17 PM   #10
PC Gator
Just wondering if this helped your problem. My wife's '01 LT is experiencing the same problem along with a hesitation at idle. It has just started.....only stalled once while parking. I just got back from running to the store and the hesitation at idle happened to me. I asked her about it and that's when I found it had stalled once.
I'll do a search for the TSBs. Any site better than the others?
Thanks in advance.
PC Gator is offline   Reply With Quote
Old 10-02-2004, 11:04 PM   #11
DucksZ
Anyone find any solutions to there problem? My wife's 2000 LS Tahoe has the same problem. It's been getting worse and worse.
I had the same thing happen with the low fuel light coming on even though I had 1/4 of gas.
DucksZ is offline   Reply With Quote
Old 10-04-2004, 10:04 PM   #12
DucksZ
For future readers looking for a possible solution.
As mentioned by GMMerlin, thanks, cleaning the throttle body solved the problem.
I have a 2000 Tahoe(new body style). The throttle is electronic no cables. There is no IAC (idle air control) that I could see. So, my conclusion.. since the throttle is electronic it can be control by the PCM and simulates the IAC to maintain a set idle. The build-up on the the throttle body confuses the PCM causing an erratic idle and stalling. After cleaning the throttle body the idle was solid no irratic idle.
Old 10-04-2004, 10:24 PM   #13
PC Gator
Smile
Same here. Cleaned the TB and the idle went back to rock-solid steady.
Old 11-17-2004, 12:17 PM   #14
lahabradq
Selman Chevy in Orange, Ca recommends cleanning the throttle body every 30,000 miles(aprox $45 at dealer) if you can't do so on your own. A fuel additive to the gas tank on occasion may help prevent frequency.
lahabradq is offline   Reply With Quote
Old 12-01-2004, 01:21 AM   #15
magglepuss
Thank You Merlin. I didn't want to spend 200 to 300 dollars to have stalling problem fixed at dealer. Thanks to you I spent $1.06 on carb cleaner, cleaned throttle body, and have corrected stalling.
magglepuss is offline   Reply With Quote
