Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-18-2006, 10:50 PM
Btd36 Btd36 is offline
passinger side front axle
Hello,
Can anybody tell me how I get the front passinger side axle out? I need to replace the balljoints and u-joints and i'm having trouble with this.
Thank You,
Brian
Old 10-19-2006, 03:04 PM
wv ranger wv ranger is offline
Re: passinger side front axle
Right axle is held in with c clip. must remove brakes, rotors, spindles. Left axle will pull out.pull right axle off splines. drain and remove differential. also disconnect front driveshaft. after differential is out, rotate pinion until you can see c clip. snap it out and the axle will pull out. I have just finished doing this to my truck, its an all day job.
