Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 10-11-2006, 06:20 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Code P1494 & P1684
P1684 is for the battery I hear.
But code P1484 - Incorrect input state detected for te leak detection pump (LDP) pressure switch.
These codes are according to my OBD II jeep codes, so they might be different for neons. I know that P0??? are all the same for all vehicles and codes starting with the #1 (P1??) are manufacture specific, but jeep and dodge are both part of chrysler so I assume they would be the same.
Old 10-11-2006, 09:18 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Code P1494 & P1684
P1494 - Leak Detection Pump Sw or Mechanical Incorrect input state detected for the Leak Detection or Fault Pump (LDP) pressure switch.
First make sure your gas cap is on correctly. If it isn't, it can trigger this code. Secondly, I would make sure that all the vacuum routings in your engine bay are connected soundly. In particular there is a vacuum line that runs from near the throttle body, around the edge of the airbox, towards the firewall and then down into some emissions control equipment. Make sure that the line is not kinked, clogged, or disconnected. The pump itself is underneath, back behind the gas tank. It has one electrical connection and several vaccuum lines running to it so be sure to check them all.
2003 Dodge SRT-4
