Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-06-2006, 04:18 PM
blainemetfan blainemetfan is offline
Passport Check engine & check trans
I have a '97 Honda Passport.. check engine light is on and we have replaced BOTH catalytic converters, all o2 sensors, EGR valve, and the damn thing still does not want to turn off....Also the check trans light comes on every once in a while and the transmission jerks hard when stopping and accelerating (its an automatic btw). the tranny was rebuilt 2 years ago and we have moved from that state so we cant take it back to that place...why would these problems be occuring.. the engine runs great and it has 93,000 miles on it. hmm??
Old 10-06-2006, 07:26 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: Passport Check engine & check trans
what are the codes for each the Check Engine Light and the Check Trans Light.
you can get the CEL read at some bigbox parts stores. the tran light may take a trip to the dealer.
you got the codes, find what they are, then go from there
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 10-06-2006, 08:06 PM
Ramblin Fever Ramblin Fever is offline
How old is your alternator?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 10-07-2006, 01:10 PM
I'll get those codes again.... The alternator is brand new, as is the battery. we just replaced both about 2 or 3 weeks ago...
Old 10-07-2006, 01:20 PM
surferfletch surferfletch is offline
What kind of alternator?
Old 10-08-2006, 08:40 PM
The only kind that you get when you go to Autozone....
Old 10-08-2006, 09:20 PM
Could be the problem.
Isuzu's don't particularly *like* just any aftermarket alternator, I myself went through 3 Checker's alternators before giving in and buying a $200 one from Bosch - bingo, problem solved.
I'm not saying for sure this IS your issue, but when these Isuzu's get a bad taste from the alternator, they WILL act really weird, transmission included.
Take that alt out, have it bench tested under load, should be nothing less then 14 vlts under load. Anything less, get rid of it, and don't bother with other part store alt's, except maybe Napa - go for a Bosch or an OEM otherwise.
1997 3.2L V6 Rodeo
Old 10-08-2006, 10:42 PM
My alternator went bad last November. I ran over to Advance because it was the only place open and they had one in stock. I ran home and put it in only to find it didn't work. I tried a new battery thinking it wasn't the shiny new alternator I put in. Didn't survive a lap around the neighborhood. The next day I bought a new one from NAPA. Has worked well for nearly a year.
Again, might not be your problem...
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 10-10-2006, 12:21 AM
wow.. thanks for the suggestions....It has been 2 days (knock on wood) that the tranny has not jerked or the tranny light has come on. Unfortunatly i dont have the funds right now to get another alternator. Great advice for the near future though. Check engine light, of course, is still on. Does reseting the computer really work in taking care of the light? I tried disc the neg. battery cable 4 days ago... then light came on the next day..im going to try and get the codes done tommorrow. i'll keep u guys posted..
Thanks!
Old 10-10-2006, 08:16 AM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Thanks!
You can also reset the CEL and clear any codes by removing the ECM fuse (15A) that is located in the fuse/relay box by the battery. This doesn't cause you to lose all of you radio pre-sets and is actually how AllData.com says to reset the light if you don't have a code reader.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 10-10-2006, 03:26 PM
i'll try that.
