93 PI CV - no electric then it comes back
I have a 1993 Crown Vic PI model and have had electical problems before that were traced to a faluty wire in the fuse box.
Issue: Car runs fine then shut off engine and when go to restart there is NO power. All lights, indicators and systems are dead. Battery shows a full charge.
Mechanic that first fixed it found a split wire coming out of the fuse box and spliced a replacement into place. This fixed that problem for several months. Now the problem is back. I checked the wire in question and there seems to be no problems with it in the lenghts that i can trace. I cannot get the Fusebox to come off the body so I can check the underside for corrosion.
I show that there is voltage in the box for all fuses EXCEPT the ingition coil. I may not have been testing this correctly, after finding no power there I went to turn the key and suddenly there was power?!?!?!?
Any suggestions on removing the box without destoying it? The bolts in the wheel well are rusted and I don't like my odds of removing them without major damage. The plastic box itself does not want to come loose from the mountings.
I feel there there may be a bad connection or crossed wire that is causing a short once and a while.
Any thoughts are appreciated.
jon
