Old 09-19-2006, 12:10 PM
534BC 534BC is offline
95 OBDII ? and scanner.
I'm told various ways to verify OBD2 on my 95 LT, but I want to make sure it will supply data to the scanners.
It has vin code W, with 4.3 engine and the computer thingy is on the pass side inner fender with many connectors. I'm told this is how to tell if it's obdII
Is it really obd2 or is there some other ways to tell for sure? I don't want to get a scanner with the options I want just to find out my vehicle will not give out the info. Is there a way to list all the parameters that can be read on my blazer?
Old 09-19-2006, 06:43 PM
sreve sreve is offline
Re: 95 OBDII ? and scanner.
it is obd1. i call them obd1&1\2. most 94 & 95 gm cars and trucks require a reader to retrive codes. some you can jump the data link connector to flash codes.
Old 09-19-2006, 06:52 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Go here and see if you have obd11 or OBD1
http://www.troublecodes.net/OBD2/
If the 16 pin OBD11 conector you can not jump it for codes.
The fender mounted VCM is OBD11
MT
MT
Old 09-19-2006, 06:57 PM
MT-2500's Avatar
AF - Advisor
Serve the 95 blazer comes both ways.
About as confusing as the 94-95 gm cars.
The fender mounted VCM on a code w Blazer is a OBD11 set up.
If PCM is behind glove box it is a OBD1
MT
MT
Old 09-19-2006, 08:11 PM
Hey thanks for the BAT link. It has a lot of nice links to scanners that I'll need to decide. I'm more confused now than I was whether or not I have 1 or 2
My VCM (with lots of wires and connections) is definately on the right fender.
My sticker says OBD1 certified
My connector is OBD2 connector
BAT says that it can have the connector, but may be obd1 and to jump pin 5&6 to get codes (like the older ones)
My connector has only pins 2,4,5,9,13,16
I think that mine is a late 95 and even though the sticker says obd1 certified, it is obd2.
Some more evidence is that I have been told by mechanics that have checked it that cyl no.1 has misfired, and I also have been told that a downstream o2 sensor was bad in bank 1. Does this necessarily mean that it is indeed obd2?
Old 09-20-2006, 08:44 AM
Blue Bowtie's Avatar
Registered Offender
You cannot question scanner comments from someone called "MT 2500" I'd think. '94 and '95 were pretty confusing years. I purposely avoid shopping for them, and that is one primary reason.
Old 09-24-2006, 04:07 PM
Maybe I'll ask the right question. I really don't care if it's 1 or 2.
What are the codes, faults, sensors I can read with this vehicle provided I have the correct tool or software?
Old 09-24-2006, 04:30 PM
MT-2500's Avatar
AF - Advisor
96 was the first year for OBD11 systems.
But on your Blazer 95 they come both ways but.
With the computer/VCM on the right fender under the coolant tank it is OBD11.
You should be able to read all P codes with scanner or code reader.
Most all OBD11 scanners will give you engine data and codes and P codes.
But a engine transmission capable scanner will have a transmission section that will give you more transmission data than just a OBD11 scanner.
Here is a list of OBD11 codes that a OBD11 scanner will read.
MT
MT
Old 09-24-2006, 04:38 PM
MT-2500's Avatar
AF - Advisor
Ask the mechanic that tested it what it was?
And post back them code no.
obd1 is 2 digit code
obd11 is 4 digit p codes
What was the code no.?
Also with a misfire alway fix the missfire first before testing 02 sensors.
A missfire can cause a 02 sensor code.
MT
MT
Old 09-24-2006, 05:44 PM
rental blazer rental blazer is offline
MT
mt 2500 I've gotta say i disagree I read on the muauls behind glovebox is obd2 and on fender is obd1 there are actilly 3 diffent boxs for 95... so yes its confuseing i do however have the box he speaks of that says obd1 cerf. on my 95 and with the 2 port inside the car and guess what...I contacted genral motors with my vin and they told me it was obd1 so if you want to be sure go to the dealer have em run your vin...thats the easyest way to know..and yes 96 and up were all obd2 .
Old 09-24-2006, 05:50 PM
Thanks for the help, I'll catch on sooner or later. I agree that mine is obd2 and my sticker that's under the hood is a generic sticker that was required for all compatible obd1 systems and merely says that it is "at least" obd1 certified, but doesn't go beyond that. I think that perhaps they went to obd2 engines and related parts yet the chassis was already built with sticker.
Anyways with all those p codes I'll get a good start on diagnosis, have to get a lap-top and have to decide on some hardware and software yet.
The mechanis gave me those codes a few years ago, I don't rmrmber the number, onlt that He said I had a bad bank 1 downstream o2 sensor. I remember being impressed with his knowledge, but never was impressed enough to change it .
Same mechanic who mis diagnosed my heater/ac problem and same guy who misdiagnosed my 4wd problem, lol.
Old 09-24-2006, 05:57 PM
What are your 2 ports in the car?
If it was obd1 then it is supposed to have A & B terminals jumped, but I do not even have those pins in the connector.
Old 09-24-2006, 06:03 PM
MT-2500's Avatar
AF - Advisor
Question Re: 95 OBDII ? and scanner.
The certified sticker sometimes gets mixed upp on what one it is.
Well the location of the PCM or VCM and the diagnostic plug is the first clue.
Here is a OBD11 conector.
And here is the OBD1
http://www.troublecodes.net/GM/
One computer behind glove box is a PCM and one on the fender is a VCM.
What is the 3th one?
MT
MT
Old 09-24-2006, 06:19 PM
[quote=MT-2500]The certified sticker sometimes gets mixed upp on what one it is.
MT[/QUOTE
the 3rd being VCM/A
Old 09-24-2006, 06:20 PM
blazee's Avatar
blazee blazee is offline
Problem?
Rental Blazer is correct that there are three different systems. He is, however mistaken on their locations. The first system is located behind the dash and is interfaced using an OBD I assembly line data link connector. This sytem is completely OBD I and codes can be retreived by jumping the pins. The second system is located behind the dash, and is interfaced with an OBD II style Diagnostic Link Connector. This system is OBD I, but requires a special scanner to retreive the codes. The third is located on the passenger side fender, above the coolant reservoir, and uses an OBD II style connector. This system is OBD II, and codes can be retreived with a generic OBD II scanner.
