Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 09-30-2006, 01:43 AM   #1
moparedDATSUN
gains??
i have some questions....Dont tell me it would be pointless, blah blah
i have a 2001 cavy 2.2 sohc
It has maybe 115 hp right?
what kind of gains could i expect with the following
bored 30 over
Head Port and polish
Flat tops for some added compression
add a set of z24 injectors (should work, right?)
Larger throttle body with a CAI
header with a 2 inch exhaust all the way back, no cat
larger cam, nothing extreme
A hotter ignition
im thinkin i might gain 45 hp...thats okay cuz i can add a turbo too
I made a buddy at work that has a machine shop and he told me that he would do the work on the motor for close to nohting. He can also get me the parts for cheap
moparedDATSUN is offline   Reply With Quote
Old 09-30-2006, 01:59 AM   #2
jakegday
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: gains??
i wont tell you its pointless, goals are good for everyone, but do you realize the 2001 2.2 isnt an overhead cam (sohc) engine, its an overhead valve.... and yes 115 hp is correct
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
jakegday is offline   Reply With Quote
Old 09-30-2006, 02:13 AM   #3
Lances133
Lances133's Avatar
Send a message via AIM to Lances133
Re: gains??
Well if you're gonna get the work done for nothing...DO IT..who cares how much it gains now, go and dyno it later.
Lances133 is offline   Reply With Quote
Old 09-30-2006, 02:53 AM   #4
Crazzzyj
Crazzzyj's Avatar
Send a message via AIM to Crazzzyj Send a message via MSN to Crazzzyj Send a message via Yahoo to Crazzzyj
Re: gains??
They have turbos for Cavaliers......? I sure hope you're not looking at that eBay crud.
~Crazzzyj
Modifications
Lightning Audio Amp and 2x 12'' Subs.
Black Altezza (Euro) Taillights.
Black JDM Headlights w/ Black Corner Lenses.
RVinyl Dash Kit.
Pioneer CD Player w/ Rear Deck Speakers.
Raceway Decal.
Apexi Dragger Muffler.
''16 Motegi Riax Rims Glossy Black.
http://www.cardomain.com/ride/2182327
Crazzzyj is offline   Reply With Quote
Old 09-30-2006, 10:42 AM   #5
moparedDATSUN
Re: gains??
thanks for clearin up that sohc..(dont really know much about THIS motor...
when i say turbo i would actually do my OWN setup..i dont do the kit trend
im more of a junkyard setup type of guy...
ive heard these motors are the best to modify, but im sure you could get some good gains if you put the work into it
I think with that motor work..keep the compression to 8.5 and not do the higher compression and stick a t3 from a 280zx with a custom manifold and an external wastegate..a 3 inch exhaust with a stock 1st gen eclipse intercooler, the car would HAUL. I would definately need to work on fuel delivery, but that wouldnt be hard..im sure a stock z24 setup would be sufficent..
that would be such a sleeper... (i have 4 door sand color car)
Old 09-30-2006, 12:48 PM   #6
MrR0b0t0
Re: gains??
Ehh actually, 2.2's are the lowest engine that comes with the cavalier, and wont get much power without some sort of forced induction. But you seem to be planning that out very nicely and im sure the engine mods your are planning on doing will help even more. Haha and I hope your jokin crazyj, hanh ftw.
'03 Cavalier 2.2 Ecotec 5 Spd Coupe
MrR0b0t0 is offline   Reply With Quote
Old 09-30-2006, 11:03 PM   #7
millrtime
Re: gains??
well ur going along the right track with just about any motor. the 2.2 non eco is proly the worst motor to modify, other than the shitty engine in the neon. and a wide open exaust and high compression dont mix just to let ya know.
millrtime is offline   Reply With Quote
Old 10-01-2006, 03:24 PM   #8
Classicrocjunkie
Lifted GMT-360!
Classicrocjunkie's Avatar
Send a message via AIM to Classicrocjunkie
Re: gains??
All of the motors that have come in these cars have their ups and downs...Name one and I can trash talk it and praise it at the same time.
The 2.2 OHV is the easyist as for hooking everything up since the exhaust manifold is right in front of you.. As far as gains with a turbo, on stock bottom end don't go anymore than 7psi and you should yeild around 160-170hp afterwards. If you do a fully built engine you can look more towards 200-220 with a proper tune. But thats thousands of dollars later... We blew the shops turbo 2200 up this fall, so we'll see what happens when she's fully rebuilt. Oil pump failed, runnin extremly lean for a little while created soo much heat it melted the fan since our manifold is a long tube design put the turbo close to it.. then melted a couple wires on top of that...
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Classicrocjunkie is offline   Reply With Quote
Old 10-04-2006, 11:34 PM   #9
moparedDATSUN
Re: gains??
hmm..thanks guys for all the input...
How would the 2.2 handle high compression? sayin maybe 10-11??
No turbo just straight built up motor with high compression
Heres the thing, im havin the guy build a motor for my dad right now (its a 360 mopar) and for the all the parts i think it came to only 500-550 bucks.
he did all the block and head work for free..
SO, can you guys that know these ohv give me some input on some good parts to use? (the man wants me to get as much info before he takes the motor) so any more help would be accepted
thanks guys
David
