98 4x4 Front End Roar
I have a roar coming from my front end that gets louder as I increase in speed. It sounds like Im riding on 44" super swampers. I replaced the right front wheel bearing about 6 months ago but this sounds different then the wheel bearing. Where should I start looking?
Re: 98 4x4 Front End Roar
Fan clutch could be frozen or locked on full - so if that open the hood and check to see if thats it.
Just checked the fan. I could spin it freely so I guess thats not it.
Could it have something to do with your encoder motor? Mine failed some time ago and I would get that exact same sound (intermittently). It would quit when I would put it into 4 high then back into 2X.
Well check the left wheel bearing.
Also you may want to look at your brakes possible seizing up just slightly enough to be making noise.
1999 Blazer 4x4 LS "Blackie" Monroe Reflex Shocks Moog U/L Ball Joints K&N FIPK Gen 2 Cold Air Intake Flo-pro Soundpro exhaust Optima Redtop 132k miles and still rolling.... |
I am having the same problem same sound. Just went through the entire front end and replaced everything from Ball joints to pitman arm... Now I am getting a moaning noise... I figured it was wheel bearing.... Blazer is perfectly streight....
Let us know how you make out... |
I have a 96 S-15 Jimmy and had a similar noise coming from the front end. Originally it was thought to be the bearings so those were replaced but that didn't fix it. Ended up having to put a new (well used) front differential end and then the noise went away. Not cheap either. Might not be your problem but might give you something to have checked out.
