Z32 Brakes
Will The 30MM Z32 brakes Fit on the 93 SE Rim? Or will i have to buy the 26MM? And do the just bolt right up or is minor MODing needed?
Re: Z32 Brakes
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car" E.K. |
Re: Z32 Brakes
30mm will clear S13 stock rims with a 5mm spacer.
Re: Z32 Brakes
but you need redrilled rotors at least, and IIRC a caliper bracket.
Re: Z32 Brakes
Sounds a little to complicated.. would i just be better off geting ones for the s13 and spend the extra benjamins or save some $$$ and go with the z32 swap?
Re: Z32 Brakes
do it so that you have more options in the future. do the 5-lug swap and put on the biggest disc you can (jon says that 30mm fits.. i have 26mm and i need a 10mm spacer to clear the calipers and there's room to spare between the disc and rim) and put on the z32s with stainless steel line and master cylinder. that way you could put on s14 wheels or whatever other 5 lug wheels you want.. trust me your options are limited with 4 lug
http://www.cardomain.com/id/dbo240 ![]() ***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE*** |
