Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 08-17-2002, 02:17 PM   #1
tcross
95 lumina stop lights
95 lumina stop lights dont work. rear turn signals work, and the center 3rd stop light works, whats the problem?
tcross is offline
Old 08-18-2002, 05:00 PM   #2
Lumina95
Check the bulbs, fuses and if that does not help the brake switch and connections.
Lumina95 is offline
Old 07-10-2003, 08:34 PM   #3
wtatham
stop lamps
had the same problem the problem is in the multi function switch. it is located under the steering wheel in the column
wtatham is offline
Old 08-02-2003, 10:12 AM   #4
Dr Sparks
Dr Sparks's Avatar
Send a message via ICQ to Dr Sparks
The turn signal voltage and the stop lamp voltage share the same wire and bulb filament on each side. In other words, you press on the brakes and the stop lamps light on both sides. If you were to signal a right turn at this point, the bulb that had up till now been burning steady with stop lamp juice will now start to blink indicating a right turn. The left side is still burning steady because your foot is still on the pedal. Bottom line is turn signal use of that bulb filament has priority over stop lamp use of it.
This branch distribution of the stop lamp switch juice takes place in the turn signal switch itself. You already know that your stop lamp fuse and switch are good because the center high mounted stoplamp is working.
So, that leaves the turn signal switch assembly as the problem component. I've never seen one that can be repaired, so it's time for a new switch. Because of driver side airbags, that repair is not for the untrained and untooled. Take it to a qualified local repair shop (or the dealer, if you absolutely have to) to have this procedure done.
Dr. Sparks
Dr Sparks is offline
Old 10-13-2003, 02:11 PM   #5
blakepoole1
Re: stop lamps
How did you take the cover off the steering column to get to the switch? Did you have to take the steering wheel off completely?
blakepoole1 is offline
Old 09-16-2006, 01:10 PM   #6
Joe Driver
Re: 95 lumina stop lights - Simple, Cheap Fix
Options: Have dealer replace switch $300 or more.
Do it your self ... switch costs $70 to over $100, need a steering wheel puller, have to pull the air bag, yada yada yada
Fix it your self with less than $10 worth of parts: Go to a junk yard and get a light pigtail from most any GM product about the same year. I got several and was charged $1 each. Pull your tail light. Look just inside of the original light and there is a "V" that is wide enough and has the clearance for your new pigtail. Take one of the pigtails you just got and using a dremel tool, cut off the "tangs". Use this as a guide to make the whole for it (about 1" if I remember). Once you have the hole about the right size, use your dremel tool to make the holes for the "tangs". Put a screw in the rear of the trunk where the light attaches and ground the new pigtail. Run a wire from the third brake light to each new pigtail and ... you're done ... FOR EVER. From the rear, it looks like exactly like the original set up.
I can provide more detailed instructions and can provide pictures if anyone wants, just email me.
Joe Driver is offline
Old 09-17-2006, 12:24 AM   #7
BNaylor
BNaylor's Avatar
Joe Driver,
Sorry but our community rules prohibit raising threads that are too old. This one dates back to at least three years or more. It serves no purpose and there is no continuity in the discussion.
Thread closed.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline
2001 Caravan Stop lights out RickCox Caravan | Voyager 0 04-05-2010 02:13 PM
93 Lumina Z34 no high stop light all of a sudden GreyZ34 Lumina 5 06-02-2009 01:51 AM
95 Lumina dies suddenly at 50mph and at stop light Tracks Lumina 4 07-27-2006 09:55 PM
98 Lumina Stop Lights & Turn Signals Buller General Discussion 2 05-10-2003 08:38 PM
95 Lumina Stop Lights tcross General Discussion 0 08-17-2002 04:04 PM
Closed Thread
