![]() Join Date: Jun 2005
Well heres a shot in the dark , picked up a 95 neon for 500 bucks. Was hit with by a dear and then they couldnt get it to start so dumped it on me. With some work i cleared up lots of problems such as
New battery New Computer New Bat cables New starter x2 first was deffective after all this car went from nada with turn of the key to a full powered crank and spark at the plugs , fuel is pumping nicely but it wont start. I havent run the codes yet, plan to on Monday but in the mean time any suggestions ? Dont mind spending some money on it but i have to get it running before i can fix the superficial damage the deer did ( windshield and passenger mirror )
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt. |
Re: 95 neon
IM getting a code 12 and 55
thought there would be more for sure
Tuning Neons since '97
Re: 95 neon
So it cranks but will not turn over?
Re: 95 neon
Cranks , there is spark to the plugs and there is a fuel smell however i havnt checked presure at the schrader valve. and the belt was replaced before i bought it, no more then 20k ago, fuel pump relay is good ,and fuses are good
#5 | ||
Re: 95 neon
![]() Join Date: Dec 2004
Re: 95 neon
i would also verify crank/cam signal is good (atleast in later 90s neons, not 100% sure about teh 95. however, same idea goes for distributor if applicable). that is where the vehicle gets the signal as to fire what signal.
basically make sure teh car isnt out of phase |
#7 | |
Re: 95 neon
OK with some work last night i found that the intake was basically *flooded* id say over 2 litres of rotten gas , sucked that out and it more or less fired up , is still running like a bag o crap but its a start , im figuring the tank is full of it too so changing out the filter tonight.
#8 | ||
![]() Join Date: Feb 2006
Re: 95 neon
there's no such thing as rotton gas. gas only becomes only more potent racing fuel, there's such thing as bad mixture though, but i don't know too much about that.
Paris Hilton says she's not a dumb blonde, it's an act. LOL if she acts so good as a dumb blonde, how come she can't act when comes to movies? hm? Quote:
#9 | |
Re: 95 neon
8.6 What is "stale" fuel, and should I use it?
"Stale" fuel is caused by improper storage, and usually smells sour. The gasoline has been allowed to get warm, thus catalysing olefin decomposition reactions, and perhaps also losing volatile material in unsealed containers. Such fuel will tend to rapidly form gums, and will usually have a significant reduction in octane rating. The fuel can be used by blending with twice the volume of new gasoline, but the blended fuel should be used immediately, otherwise teh old fuel will catalyse rapid decomposition of the new, resulting in even larger quantities of stale fuel. Some stale fuels can drop several octane numbers, so be generous with the dilution. http://science.howstuffworks.com/fra...ine-faq/part1/ Right from a horses mouth other then my own, the old gas from my car is now killing unwanted grass in my driveway.
#10 | ||
Re: 95 neon
well i did tell i didn't know everything about it, i humble enough to accept correction when it's nessesary.
#11 | ||
Re: 95 neon
#12 | ||
Re: 95 neon
#13 | |
Re: 95 neon
Mine did the exact same thing the problem is still a question.I had a diog done and dealer said it was timing.Among other problems i changed the timing belt water pump and both belts.turned the key and it fired right up.(after 3-4 secs)This is my prob now!! checked timing again and its right on!! I touch a screw driver to my comp disconnecting my battery.I bought an OB2 and it would not read anything ERROR is what it said.I dont know?the manual said there was a prolem with the connection between the OB2 and the comp. thats as far as I have gotten......
#14 | |
![]() Join Date: Apr 2006
Re: 95 neon
Is your car standard or automatic? I have a 1995 standard.
Here's a pic of me on my maiden voyage after replacing the clutch and clutch cable myself. ![]() Here's a pic of how the voyage concluded: ![]() Solved the problem by cleaning the battery terminals. Got any pics of your 95? Does it still have paint (unlike mine)? |
#15 | |
Re: 95 neon
i have the same car except its white base model only upgrade it had was an auto tranny
![]() but all need is an ecu then I can switch to stick you wont get any codes since you switched pcms haha i cant see why the pcm would go they normally last a long time |
