Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-21-2006, 03:06 PM   #1
katbrom
Question fuel pump?
I have a 1997 plymouth neon 5 speed. I was turning a corner the other night and my car died without warning. It will turn over but won't start. Also, the oil light is now on. I still have about 1,500 miles before my next oil change plus the oil level is good. Any ideas? Could it be the fuel pump? If so, is that difficult? Expensive to have done? Thanks, Kat
katbrom is offline   Reply With Quote
Old 08-21-2006, 07:12 PM   #2
Bear
Re: fuel pump?
Could be fuel pump and if you have a little mechanical ability you can do it yourself (pump is in passenger side of fuel tank and you may need to lower tank a bit to get pump out). most pumps have a lock ring that you must turn off to take out fuel pump (a Haynes manual will be of great help here). I have not priced a fuel pump laely but I would guess they are in the $150.00 range. Another possibility is the Crankshaft Position Sensor, it failed on my '98 and she would crank but not fire. Try this, turn key to on and see if you hear the fuelvpump buzz at it pressurizes, if you can, the pump is working.
Bear is offline   Reply With Quote
Old 08-30-2006, 09:47 PM   #3
JSUsaxman
Send a message via AIM to JSUsaxman
Re: fuel pump?
I just replaced the fuel pump in my 97 and I got it at Advance Auto.
If you dont have a plastic tank its $170 but if you do like me its $214.
JSUsaxman is offline   Reply With Quote
Old 08-31-2006, 08:21 PM   #4
Will183
Re: fuel pump?
Another possibility to look into would br your timing belt. These also let go without warning and depending on your motor, after cranking it, you may have caused a world of hurt on your head(eg.bent valves in it and holes punched in your pistons). So if you do hear the pump working when you turn on the key, I would open the timing access cover at the top of the motor and watch the cam gear as someone else cranks it and go from there.
Will183 is offline   Reply With Quote
Old 09-03-2006, 10:15 PM   #5
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: fuel pump?
Oil light in a 97 doesn't mean time to change the oil. It's either low on oil or had oil pressure at the time.
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Old 09-07-2006, 03:11 PM   #6
brandcrx88
Re: fuel pump?
Replaced my fuel pump, Very simple w/ the right tools and a buddy. make sure you drain that tank before you try to move it, very messy. my pump was 220 at napa. good luck!
brandcrx88 is offline   Reply With Quote
Old 09-11-2006, 01:15 PM   #7
yale329
Re: fuel pump?
I think your fuel pump seal in the tank bumbed out, I agree.
Best of luck. Can you remeber if your tank was low on fuel at the time. If it was check the above.
Best of luck Wayne
yale329 is offline   Reply With Quote
