Old 09-08-2006, 07:21 PM   #1
mike_flemming
Need help for project tomorrow!! (removing rear window carpet)
Yes, well tomorrow i was going to put my new pioneer 6x9 speakers the the back of the car. I would like to have the speaker grille above the rear carpet. Im assuming that i can cut holes for this. But I have no idea how to remove this peice. Im assuming i have to remove the child seat anchor and the 2 side plastic peices...anything else? (thanks in advance)
mike_flemming is offline   Reply With Quote
Old 09-08-2006, 09:54 PM   #2
mike_flemming
Re: Need help for project tomorrow!! (removing rear window carpet)
anyone?
Old 09-08-2006, 11:29 PM   #3
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
What year Lumi? On the later body style ('95+) the rear seat cushion is removed, the seat back needs to come out (one nut in each lower corner), and then the entire rear package shelf slides out in one piece.
Old 09-09-2006, 09:15 AM   #4
mike_flemming
its a 95
Old 09-09-2006, 10:56 AM   #5
richtazz
stupidity should hurt
richtazz's Avatar
Your 95's rear speakers bolt in from up top, so the rear seatback will have to be removed to get the top shelf carpet out. It appears the lower cushion is held in by a single bolt in the center above the floor hump. The seat back has 2-bolts on the bottom near the outside (one on each side). Once you get the shelf carpet out, you can cut your speaker holes if you wish. My advice would be to leave it alone so your visible speaker grills aren't a clue to theives that you have a nice system worth taking.
Old 09-09-2006, 09:47 PM   #6
uH8THECHEVY
uH8THECHEVY's Avatar
Send a message via AIM to uH8THECHEVY Send a message via Yahoo to uH8THECHEVY
I agree. I have 4 6X9s in my 1991 Lumina but you can't tell from looking thru the back window.
uH8THECHEVY is offline   Reply With Quote
Old 09-11-2006, 06:21 PM   #7
gw84
gw84's Avatar
Send a message via MSN to gw84
how do you remove that piece in a first gen. lumi? Mine looks rough, I'd like to replace it
This ain't your grandma's car!!
gw84 is offline   Reply With Quote
Old 09-11-2006, 11:23 PM   #8
uH8THECHEVY
Remove the two bolts for the bottom of the seat(13mm Socket) and the the two for the back part of the seat (I think a 11mm Socket). Once you have those two parts off you need need to remove the retaining pins that are holdinn the covers for the seatbelt. Also there are two pins I think in the middle of the carpert also.
Once you have all of that removed all you have to do is slide the carpet off.
