Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-21-2006, 10:59 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Exclamation Race gas, 93oct pump gas + MOTH BALLS??
ok, so i read that you can increase the octain of gasoline. anyone ever tried this? i know the moth balls have to be naphthalene (s/p) based and such, but it just seems weird to drop a few moth balls into my gas tank, then fill it up... but if it works... hell! anyone?
Old 08-21-2006, 11:12 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Race gas, 93oct pump gas + MOTH BALLS??
You could use acatone to
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 08-21-2006, 11:46 PM
Black99GST's Avatar
this really would work? how much would it boost the octain? beacuse if its some small amount thats not even worth it, then why bother... but if it really works, i'ed like to know what mixture works the best.
Old 08-22-2006, 12:10 AM
blk_srt's Avatar
There was a big write up a while back if you search for it
Mods:
Old 08-22-2006, 01:43 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Yeah you would want to use Xylene...I think thats how you spell it...but there was a big write up on it a while back.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 08-26-2006, 12:21 AM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Yup thats what I run from time to time.
Here are some info on homemade oct boosters.
http://www.dsmtalk.com/forums/showth...threadid=23700
http://forums.turbobricks.com/showthread.php?t=11771
Read those, it tells you how much to mix and what the kind of octane rating you will get.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 08-29-2006, 10:59 PM
Black99GST's Avatar
awsome, but does anyone happen to know what works best?
Old 08-30-2006, 01:59 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
well you can use standard paint thiner which has Xylene and toulene this is the mix you want as toulene is the #1 mix in most octane boosters,Xylene is harder to find by its self but its usaully found in the higher priced octane boosters,but as i said a standered can of paint thinner is both mixed with minerals to clean fuel injectors and shit.if you use paint thinner make sure you add some tranny fluid for lubrication,not sure how much but if you check you can find out.i remember reading about this somewhere.hope i helped later guys.
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 08-30-2006, 02:09 PM
Black99GST's Avatar
hmm... i wish keven would reply on this or someone who is really knows what they are talking about... not saying you dont... i just would feel alot more confident pooring transmission fluid into my gas tank if they agreed... lol
Old 08-30-2006, 02:15 PM
BOSTONjoe98gs
ok,but when you do it you need some sort of lubricating agent and most people use auto tranny fluid.and if you dont believe anyone but kevin,then pm him
here ya go..for 8 16oz bottles
100 oz of toluene for octane boost
25 oz of mineral spirits (cleaning agent/"fuel injector cleaner!" not required in the mix!)
3 oz of transmission fluid (lubricating agent)
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 08-31-2006, 07:50 AM
kjewer1 kjewer1 is offline
AF - Advisor
Trans fluid will work. If I were to try this though I would use Marvels Mystery Oil for the lube, but that's just me. It's an oil that was meant to be burned in the CC, so it seems like a better option IMO. Either way, just be sure to use something. The toulene/xylene mixes are a long time proven method for increasing octane.
I still say race gas is the way to go. It's engineered for this task, not cobbled together. I don't like to cut corners to save a buck or two when I'm pushing the limits. In fact I pay 9.50 a gallon for the Sunoco 117 I run. It hurts the wallet, but so do toasted motors.
For constant street use, something like a meth/alky kit is worth looking into. People are having impressive results with that stuff lately!
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-31-2006, 01:07 PM
Black99GST's Avatar
ok thanks keven! ig uess, what all is needed to set up a meth/alky injection system? and that will help redudce knock?
Old 09-01-2006, 09:25 AM
AF - Advisor
It will certainly help if done correctly. I have seen some MEAN setups. The example I like to use is one about a guy on the DSMlink forums. He posted a log indentical to the one I got from my 11.3 at 126 run. The difference was I was on 10 dollar per gallon race fuel, and he was on pump with water/meth injection. And in fact, he went out and trapped 126 mph with it as well, and then even better eventually. He had quite the setup though. I recomend lots of research. I could sum up what I Think works based on other's results, but I have never tried it, so you would be better off to look into it on your own. See if you can find this guy on the national forums, I believe his name was Ron Francis, Lokmeup as a screen name. I think he even had a web page made with details of his setup.
FWIW, I'm thinking of trying something like this. Water/alky/meth injection is immensely popular with EVOs (most poeple use a prebuilt kit available from the EVO vendors, like the Snow kit, look into that one, even summit carries it IIRC). I'd like to try something a little different though, like what Ron did.
Kevin Jewer
Old 09-01-2006, 11:16 AM
Black99GST's Avatar
ok, i'll look intot hat, thanks Keven!
