Go Back   Automotive Forums Car Chat > Car Audio
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 08-28-2006, 06:26 PM
talonesiboy talonesiboy is offline
Exclamation amp +sub question
i have a mono alpine amp and i sony 4 channel and i was wonderin if you can use to rear channel for the sub like connect the mono and the rear channel for more power for the sub can that be done
Old 08-28-2006, 06:44 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: amp +sub question
please reword that so we can understand what you are saying.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 08-28-2006, 06:48 PM
bjboertje's Avatar
do you mean you want to use both the mono amp and the rear channels from the 4 channel to power the same sub? no, do not do that.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
[quote=talonesiboy]i have a mono alpine amp and i sony 4 channel and i was wonderin if you can use to rear channel for the sub like connect the mono and the rear channel for more power for the sub can that be done...i mean is can i use to rear outlet and connect the bridge wire coming out the 4 channel amp with the mono amp wire like join those 2 toegther for more power to the sub
Old 08-28-2006, 06:51 PM
bjboertje's Avatar
you seriously need to go back to english class. no you can't do that.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 08-28-2006, 07:21 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Powering a speaker with 2 amps is bad, mmkay? I had someone come to me one day and ask why their amps fried. I looked and he had 2 amps piggy-backed(one straight into another, then to the speaker........) I would've smacked him, but the ass chewing was enough(One amp was MINE!!!)
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-28-2006, 08:59 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Why don't you just use the 4 channel amp to run the inside speakers hooked to the front rca output on your amp and use the mono amp to push your sub only hooked to the rear rca output of your headunit?
Old 08-28-2006, 10:24 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you CAN put two different amps on one speaker ... each on one side of a dual voice coil sub, but you better know what you are doing. And NEVER put the output of one amp into the input of another.
Old 08-28-2006, 11:31 PM
Your right...I wasn't thinking about DVC's....
