Go Back   Automotive Forums Car Chat > Ford > F Series
F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750.
Old 08-14-2006, 07:00 PM
imakeitcold imakeitcold is offline
F150 300 Engine Has Miss
I Have 1989 F150 200,000 Miles That Has A Miss While Traveling Down The Road. It Seems To Idle Ok Most Of The Time. When It Starts To Miss If You Give It Gas It Stops The Miss Until You Settle Out To Whatever Speed You're Traveling. Some Times It Will Act Up More Than Others. I Have Had The Fuel Filter Changed But I Can't Determine Whether It's Fuel Related Or An Electrical Problem. I Just Had Some Problems Fixed On The Fuel Pump Not Geting Enough Voltage. But The Miss Has Been A Problem That Has Been Getting Progressivly Getting Worse Over The Last Year Even Before The Other Repairs.also Switching Tanks Makes No Difference. Any Ideas??
Old 08-15-2006, 02:09 PM
smlblck smlblck is offline
Re: F150 300 Engine Has Miss
how many miles is on the engine?
Old 08-15-2006, 05:15 PM
I don't know for sure. I put around 50,000 on it since I've had it. It appears to be original.
Old 08-28-2006, 07:36 PM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
Have you got into an accedents, no matter how small the collision if the ECU got bumped the right way it could ahve messed up the timing or the mapping.
Old 10-18-2006, 11:10 AM
armstrong armstrong is offline
Does it only miss at high rpm? Have you checked to make sure your getting all of plugs to fire in the correct sequece?
