Old 08-07-2006, 02:28 PM   #1
gw84
gw84's Avatar
Send a message via MSN to gw84
fixing scratches?
I was wondering what is the best method of repairing minor scratches. Do those little bottles of touch up paint work or will they fall off in the rain.
This ain't your grandma's car!!
gw84 is offline   Reply With Quote
Old 08-07-2006, 03:57 PM   #2
tblake
In God We Trust
tblake's Avatar
Re: fixing scratches?
they work ok. I always touch up the new rock dings in my hood after i wash. I'd get one from the dealer with the vin so its an exact exact match. Avoid Plasticate (wall-mart brand) that paint is very runny and a lot of times requires you to go over it again and again and again.
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
tblake is offline   Reply With Quote
Old 08-07-2006, 04:01 PM   #3
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
http://www.langka.com/
If done properly, they are almost undetectable.
Old 08-08-2006, 06:42 AM   #4
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Read the paint codes for your car off the sticker, get BOTH codes, the base and the clear...
The touch up paint works best IMO if just dropped into place, not brushed on, as it will sink and level out as it drys...the area should be very clean or it won't stick well, and you'll be doing it again in a couple of months.
Drop the base color on it and allow to dry and repeat until you have 2-3 layers of base, and the scratch is filled nicely, then topcoat it with clear to seal and match shine...after it all sets for several days, you can go over the area (noit real aggressively) with some buffing compound to blend your job to the surrounding area a bit better...then wax it in...
...empty gun rack.
Old 08-08-2006, 06:50 AM   #5
jeffcoslacker
If your car is a dark color, I'd suggest Zymol...I discovered there is nothing like it for dark colors (especially black) to put the darkness and depth back in into it, I heard (maybe on the bottle?) that it's what they use on the royal carriages at Buckingham palace to keep that black laquer slick looking...the SS looked like a bottomless pool after using that stuff, it became all I'd use...takes out fine clearcoat scratches and swirls from car washes, etc...leaves it looking like it's wet...very cool, well you can make that out in the pic, it was just washed, but i'd towel dried it, still looks wet, no?.
Get liquid in the bottle, not the paste in a can. It's sky blue colored
...empty gun rack.
Old 08-08-2006, 06:55 AM   #6
jeffcoslacker
...empty gun rack.
Old 08-08-2006, 12:39 PM   #7
tblake
In God We Trust
tblake's Avatar
yeah, last time i waxed i used zymol. I thought maybe being a different color that it would be easier to wax a white car, but after its applied it looks the same as any other. I did also really like it, well worth the 18 bux spent on it.
Old 08-08-2006, 01:38 PM   #8
Manny_boy
Manny_boy's Avatar
Zymol is some good stuff. It worked so well, I contacted the company to tell them how impressed I was, and they sent me a full color catalogue of their products.
Behind a calm face is a disturbed mind controlled by music...
Junkyard Dog - Be careful...it bites!
Manny_boy is offline   Reply With Quote
Old 08-08-2006, 07:36 PM   #9
gw84
gw84's Avatar
Is the Zymol a product to use after repairing scratches or does it actually fix minor blemishes itself. Also does anyone have any thoughts about "Dr. Color Chip"? I read about it in the car detailing forum. Thanks everyone for the input.
Old 08-08-2006, 08:26 PM   #10
jeffcoslacker
It will clear very fine scratches, like from car wash brushes or salt etching, that make the clear dull, it won't "fix" scratches...I suggested it after a touch up repair to make the repair blend into the rest more seemlessly...
...empty gun rack.
Old 08-08-2006, 08:37 PM   #11
gw84
gw84's Avatar
thanks for the info. I've got a few blemishes I'd like to fix. I'll try the Zymol. I guess I'm gonna go to the dealer for the paint. Is there anywhere to get it cheaper?
Old 08-08-2006, 09:26 PM   #12
jeffcoslacker
http://www.expresspaint.com/productc...&idCategory=21
LOVE the touch-up pens....easiest thing there is to use...verify your color.
...empty gun rack.
Old 08-08-2006, 09:39 PM   #13
jeffcoslacker
http://www.automotivetouchup.com/paintpen.asp
Here's a bit cheaper source for the touch up pen....there may be even cheaper, I don't know...
Beats the hell outta motorcycle OE color pens...I had to pay $35.00 EACH (x2, base, clear) for my kawasaki...farg...
...empty gun rack.
Old 08-09-2006, 07:21 PM   #14
gw84
gw84's Avatar
thanks jeff. Have you tried that specific brand with good results? I guess I would need to buy the primer, basecoat, and clearcoat to do it right. I'm pretty sure my color is "dark carmine red metallic" but I think I'll check my paint code just to be sure.
Old 08-09-2006, 07:55 PM   #15
jeffcoslacker
you don't need primer...I'd bet you arent scratched through the primir...that's prtty hard to do..
I've used both of those brands in pen form...
...empty gun rack.
