Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-07-2006, 01:13 PM   #1
jdrumstik
jdrumstik's Avatar
Spark Plugs 3.3L 89 Cierra
I have an 89 3.3L Cutluss Ceirra.
I am trying to change the spark plugs, but I can't get to them!
My last car was an 88 Honda Prelude, extremly easy to change the plugs. But this Olds is much harder. I've looked at manuals in Autozone (Hanes) and the Online stuff at autozone and they all give direction for a completley differnet engine.
Mine is a distributless, EFI engine; and I can't get the boots out from under the metal block that sits on top of them. I've removed all the bolts and clips on the metal block. Their are fuel rails connecting to the metal block that I don't want to remove unless I have to. Any advice. Anyone familiar with this engine?
jdrumstik is offline   Reply With Quote
Old 08-09-2006, 07:08 PM   #2
caddyman379
Re: Spark Plugs 3.3L 89 Cierra
i have a 92' ciera with the same engine. On mine, I didn't need to remove anything. I used a spark plug socket and a driver without any problem..The engine needs to be cool however as you'll need to rock the boot side to side while pulling. Grab it by the metal part and they should seperate without too much effort.
That was my experience anyway, good luck to you
caddyman379 is offline   Reply With Quote
Old 08-10-2006, 10:34 AM   #3
xeroinfinity
out saving the world
xeroinfinity's Avatar
they sell a tool that removes those stuborn boots.
Which ones are you having troubles with, the back side?
You really should not hav to remove the ignition block.
heres a tip , when you get them off, be sure to use some silicone stuff for the plugs boots.
Makes it real easy the next time they need to be removed.
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
