Go Back   Automotive Forums .com Car Chat > Engineering/Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-08-2002, 10:33 PM   #1
Tominos
turbo help
ok, i just got my turbo today. i bought it off of ebay, and this thing is pretty big. i don't know the specs, trim etc. on this, but i don't think its going to fit in my engine bay, even with a turbo manifold without taking the a/c out. i have no experience with turbos but this thing seems to take up the whole space in front of the block. also i need to spin the inlet of the turbo around so it'll face down or up or whatever, because right now it is faced toward the block if i bolt it on with the downpipe facing the drivers side of the car. anybody know how to do this? i heard you loosen the bolts, but i dunno which ones. any help would be great. thanks
Tominos is offline   Reply With Quote
Old 07-09-2002, 12:15 AM   #2
Polygon
The Red Baron
Polygon's Avatar
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I would say put it between the engine and firewall if at all possible. Though I know very little about your engine.
Polygon is offline   Reply With Quote
Old 07-12-2002, 07:44 PM   #3
Tominos
anybody? can you guys tell me where i could find info on rotating the compressor and the oil inlets/outlets, etc. i loosened most of the bolts on the compressor side but there are two bolts holding the wastegate bracket on to the compressor that are impossible to get to with my wrench/socket. i know somebody knows where, please tell. thanks
Old 07-25-2002, 05:33 PM   #4
PFCfutrell
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
LOL... the exhaust manifold of a Civic is between the radiator and the block, not the block and the firewall. Your Chrysler and my mom's VW have the turbo between the block and the firewall so I know what you were thinking.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
PFCfutrell is offline   Reply With Quote
Old 07-26-2002, 11:23 AM   #5
Rgacke
Rgacke's Avatar
1st off, what type of turbo is it? is there a clamp holding the cartridge and exhaust housing together? if so take off the clamp, pry the two apart, rotate, clamp together and your done. If not, let us know
"shut the door Joshua, and let death pass by..."
Rgacke is offline   Reply With Quote
Old 07-26-2002, 01:37 PM   #6
Tominos
its a t3 turbo. already figured out how to rotate it, its just the bolts are in awkward positions and my wrench can't fit in there. thanks alot for the help.
Old 07-26-2002, 04:32 PM   #7
Polygon
The Red Baron
Polygon's Avatar
Oh, hehe, yes that might be a problem then.
Old 08-29-2002, 03:24 AM   #8
i8v8
Send a message via AIM to i8v8
it will fit. a t3 isnt too big. and especially if you bought the turbo kit specifically for your sohc vtec motor. just get some pro help installing it.
i8v8 is offline   Reply With Quote
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
